Old 09-08-2014, 03:48 PM   #1
Big Blue
Big Blue's Avatar
AC Question (s)
I have a project that I am doing. It did not have AC. I am putting AC In it. I took parts from an AC truck. What I do not have is the wiring that goes to the compressor. If I were to add that wire where do the wires go to ? Any help would be great, pictures are even better. Second question, what type of compressor can I use since it had none? What would I need to install it?
Thanks, John
Big Blue ( John )
79 Chevy Pick up.....My Dailey
STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in.
Big Blue is offline   Reply With Quote
Old 09-08-2014, 10:14 PM   #2
Big Blue
Big Blue's Avatar
Re: AC Question (s)
Mods, Could you please move this to Electrical for me.
Thanks John
Big Blue ( John )
Old 09-08-2014, 10:20 PM   #3
48cj2a
48cj2a's Avatar
Re: AC Question (s)
I'm doing the same thing with my CUCV Blazer. I'm using the long A6 compressor (84 and earlier) and slowly piecing the parts together to complete.
If you do a search there are a few here who have done it too.
03 Suburban Z71 Z71
98 GMC Yukon SLT 4x4 Yukon
86 M1009 CUCV Project Milverado
48 Willys CJ2A 48CJ2A
48cj2a is offline   Reply With Quote
Old 09-08-2014, 11:36 PM   #4
hatzie
Moderator
hatzie's Avatar
Re: AC Question (s)
The compressor clutch wire should be run from the Low pressure cutoff switch.
The wiring manuals for all the CK RV squares from 73-91 are in my signature.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
hatzie is online now   Reply With Quote
Old 09-09-2014, 07:23 AM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: AC Question (s)
Go here for installing removed components. A/C for 73-87 trucks.
Ditch the stock compressors for a Saden 508. You'll need new hoses. R134 is a smaller particle than R12. Over time, R134 will leach out of R12 hoses. R134 hoses have a plastic barrier between outter and inner walls. A cross flow condensor is also needed. O'riellys carries cross flow condensors for our trucks.
Wiring is switch->low pressure switch->high pressure switch->clutch-> to good ground. The pressure switches are in series to cut power.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
