Old 09-14-2014, 11:08 AM   #1
03glide
Sell it before it's finished
03glide's Avatar
A little help on a 4/6 drop please.
I received my CPP 4/6 drop kit a few days ago. I managed to get the flip kit installed over the last couple of days(in between work and 4 kids). This morning I started on the front. Everything was going well until I tried to re-install my rotor. The spindle diameter is larger than my old one. After some searching I found most manufacturers list 2 kits for different brakes. I wasn't asked about brakes during my order(phone order) process. After the 3 week wait and lack of communication from the vendor during this order I was hoping to avoid returning the spindles. Can I simply but the new rotors/bearings that match these spindles? Will my current calipers work or will those need to be replaced as well. If you have run into this and can offer advice it would be greatly appreciated.
Brian
03glide is offline   Reply With Quote
Old 09-14-2014, 11:15 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: A little help on a 4/6 drop please.
There are 2 choices when it comes to 73-87 spindles.
1" wide rotors or 1-1/4" wide rotors.
EVERYTHING has to match the version you have.
Rotor, caliper, spindle, and bearings.
Sounds like your truck had the opposite of what CPP sent you.
I'm guessing your truck had the Light duty 1" rotors.
Keith
Convert to disc brakes.
Old 09-14-2014, 11:16 AM   #3
79Betty
79Betty's Avatar
There is 1.25 "heavy duty" rotors, and 1" standard rotors. Sounds like ya have big n need small. Idk about the calipers but that is all i know.
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 09-14-2014, 11:34 AM   #4
03glide
03glide's Avatar
I think I will just buy new rotors and calipers rather than send these back. They are pretty old and it wouldn't hurt any way.
Old 09-14-2014, 07:24 PM   #5
03glide
03glide's Avatar
Went and picked up new rotors, bearings and calipers. Now front brake lines don't work with the calipers. Go figure?? I'm pretty sure that the steering wheel will need to be replaced by the time this is over.
Brian
Old 09-15-2014, 05:42 PM   #6
VTX-Black
VTX-Black's Avatar
Might as well order new tail lights while you are at it :-)
VTX-Black is offline   Reply With Quote
Old 09-15-2014, 09:22 PM   #7
03glide
03glide's Avatar
I new I forgot something!
