#26 |
Re: one piece at a time
Nice progress
#27 |
cab corner looks nice.i really like your build.
#28 |
60-66 Nut
Your build is looking good.....I agree on nice job on the cab corner.
#29 |
thanks guys! i try to do at least one thing a day to it ,no matter how small it my be it is still progress.
Between saying and doing many a pair of shoes are worn out ![]() |
#30 |
well i got my mustang tank in today. i had to cut allot more than i really wanted to on the frame. i didn't think it was going to take that much to fit it in there. all well its to late now im committed to it , think i may box that area in the back. tomorrow im going to change my track bar mount on the frame from the 65-66 mount to the 63-64 so i can use the adjustable track bar i bought.
#31 |
cut my track bar rivets out on the frame and ready for the new 63-64 one.
welded the rear cross member in also did what im going to call a mini box on one side. that way i can still reach the top side of the inside of the rail so i can bolt in my mustang tank. will finish the other side tomorrow
#32 |
well not much to report cut 2 holes in the core support for a/c lines .i finished body work on splash pan and finder, hope to get them painted this weekend.
found some satin black auto paint made by Rustoleum sold in quart cans going to try it.
#33 |
found another bed not much better than my other but it was the right price not much to report on just allot of sanding ![]()
#34 |
Busy Saturday for me first went to the salvage yard and cut a new radio hole. I pulled the windshield and striped around the hole ,spilling paint striper on my dash. As a result I started striping the interior down to metal and pulling all my stickers off. I have not decided what color I am going to paint the inside. I may go with black same as the outside with touches of green, since I already bought the green carpet. I finally took a picture of my finished speaker hole patch on my passenger door.
#35 |
wish I had a time machine, I would go back in time to the 1970S and kick the guy right square in the nuts that painted my truck with what i think is coper colored lacquer. that stuff you couldn't dynamite off. I threw paint striper at it and it just laughs at me, i even used the good aircraft striper. so after 2 days of hitting the inside of the cab with 10 of the 3m striper wheels it is finally bare metal. now 90% of my cab is in etching primer just need to strip the floor pans back down to give a good base for a coat of kbs rust seal for good measure. also a update on my small trucks the gmc is almost done just a few more odds and ends, as for the crew cab it has a long road ahead.
#36 |
I cut my dash today and started welding it up then i was hit with a giant puff of smoke. then I realized my heater ran out of diesel so i wimped out and stopped, i hate being cold.
#37 |
![]() Join Date: Feb 2014
Nice work! What are you using to strip the paint?
#38 |
![]() Join Date: May 2007
looking good
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#39 |
paint/rust striper wheels got 10 of them off ebay for $25 they work well. 3m also makes some you can normally get the wall-mart for $10 each.
#40 |
#41 | |
#42 |
finished metal work now just need to do some filler work.
ATTACH]1326267[/ATTACH]
#43 |
Good job on the metal work!
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
#44 |
thanks! i have learned a-lot over the past year from being around the guys that work in the metal fab side of the restoration shop i work at. some times i think i get on there nerves from asking so many questions(they usually tell me to get back on the mechanic side lol ), but im a young guy at 24 years of age and want to learn what they know.
#45 |
Dash body work done only 3000 more dents and dings to go
#46 |
Great job on the dash. Lookin reeeeeeal good
#47 |
Thanks wasn't really sure of myself that it would turn out that well.
I shot some primer on my other door and finder Today and touched up my drivers door.
#48 |
your paint booth has a lot of light
#49 |
Yep and wind it's definitely well ventilated
#50 |
Yea found more rust, luckily hand another cab corner laying around so I started replacing it. Found a seat to recover to replace my bucket seats that I had. I trained a short bed 84 rolling frame for a working t56 six speed for my long bed 3/4 ton also bought a disk brake front end from a 71.
