Old 12-18-2014, 01:52 AM   #1
sgr60
Remove extra bracket?
I want to take this bracket off - I'm not sure what used to be connected to the top portion, but it seems to be mostly excess at this point.
There is, however, one spot at the bottom where the PS pump is bolted to it. My question - is this supporting the PS pump, or is the PS pump used as a mounting point for the bracket?
If it is supporting the PS pump, does anyone know if there is a lower bracket for the PS pump that doesn't have all the extra that this one does?
It doesn't look like the PS pump bracket kit from LMC has it: http://www.lmctruck.com/icatalog/cc/full.aspx?Page=150
Thanks!
'84 K20 350/465/208
sgr60 is offline   Reply With Quote
Old 12-18-2014, 02:16 AM   #2
sgr60
Re: Remove extra bracket?
Oh, and I forgot to mention - I'm going to be putting headers on shortly, so I'm going to have to get rid of that bracket one way or the other...
Thanks!
'84 K20 350/465/208
Old 12-18-2014, 07:00 AM   #3
chengny
chengny's Avatar
You are missing some of the rear compressor bracketing parts and the main rear cylinder head-to-compressor brace is being used basically as just a P/S pump bracket.
Here are some images that should help you figure it out:
With non-AC, brace 10 takes the place of all the other parts in the lower RH corner (first dwg). Here is what the P/S pump bracketing for a non-AC truck looks like:
So, if you remove that main rear AC brace you will have to find a brace as above to anchor the outboard rear P/S bracket.
chengny is offline   Reply With Quote
Old 12-18-2014, 11:14 AM   #4
sgr60
Awesome - thanks for the reply. Anyone know what would need to be done in order to get the ac and power steering to mount up with headers? I can't imagine that stock bracket would work even with spacers...
'84 K20 350/465/208
Old 12-18-2014, 12:07 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Leave it all there and use spacers under the brackets between the brackets and the header flange. Works fine that way.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-18-2014, 12:27 PM   #6
sgr60
The headers call for this bracket to be used with AC -
https://www.holley.com/products/exha...parts/10925HKR
I can't see how this would work though, not sure where it would be used.
'84 K20 350/465/208
Old 12-18-2014, 01:27 PM   #7
Tx Firefighter
That bracket you referenced is for an A6 type of compressor, which was the type before your R4 compressor.
http://documents.holley.com/10925-6hkrrev1.pdf
All you have or do is remove the bolts and slide the exhaust manifold down and out, then slide headers up in place and cut two little spacers to fill the gap between the header flange and the current bracket.
Old 12-18-2014, 01:35 PM   #8
sgr60
Great - thanks. I took another look at my setup and I'm having trouble matching it up to the diagrams... Will take some photos a little later - hopefully it's just something simple...
'84 K20 350/465/208
Old 12-18-2014, 04:17 PM   #9
piecesparts
Parts and more parts
piecesparts's Avatar
I kept the bracket and cut away all of the extra stuff on it for my stroker engine. I put headers on and still use the bracket, I just don't use a header bolt in that spot, I have the original bolt with spacers under the bracket to keep everything aligned.
Frank
Old 12-19-2014, 12:54 AM   #10
sgr60
OK, I took some more photos. Like I said, I'm having trouble matching up what I have to the diagrams above. Maybe I'm just not seeing it correctly, or I suppose the PO could have messed with it even more than I originally thought (entirely possible).
So here's where I'm at - first, on the AC diagram -
I see brackets 20 and 14 (I think), but I don't see 16 or 21 on the front. I do see that I am missing some of the rear left stuff that should attach to the large bracket that I originally posted about (3). Would that be 7? And 10 is for trucks without AC only?
On the Power Steering pump diagram -
I see bracket number 6 and 12, but not 13. 13 I think is the same as 7 in the other diagram.
Thanks!
'84 K20 350/465/208
Old 12-19-2014, 11:07 PM   #11
sgr60
Any thoughts?
'84 K20 350/465/208
Old 12-19-2014, 11:44 PM   #12
Just call me Sean
Just call me Sean's Avatar
Looks like you're only missing the rear compressor bolt and spacer. Power steering pump has three bolts, one pivot and two slotted. As long as there are three bolts holding it you have everything. Those bracket diagrams don't look right to me. This is the best pic I have of what is down there:
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 12-21-2014, 02:08 PM   #13
Axle
Axle's Avatar
You only seem to be missing a couple bolts and the spacer (compressor takes metric bolts btw).
Alex.
Axle is offline   Reply With Quote
Old 12-22-2014, 12:07 AM   #14
sgr60
Anyone know where I can get the missing hardware (bolt, spacer, etc.) from?
'84 K20 350/465/208
Old 12-22-2014, 01:10 PM   #15
piecesparts
I would just go to an automotive supply that has bolts in metric sizes, for a start.
Frank
