Old 01-01-2015, 06:44 PM   #51
hotrod66
hotrod66's Avatar
Re: one piece at a time
Well finally finished replacing my passenger cab corner.
Think my drivers side turned out better.
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 01-01-2015, 07:52 PM   #52
pimpston65
pimpston65's Avatar
Originally Posted by hotrod66 View Post
paint/rust striper wheels got 10 of them off ebay for $25 they work well. 3m also makes some you can normally get the wall-mart for $10 each.
Attachment 1325969
Attachment 1325973
can you prime right after using the wheel? or do you need a finer grit to remove those scratches made by the stripper wheel?
pimpston65 is offline   Reply With Quote
Old 01-01-2015, 08:16 PM   #53
hotrod66
hotrod66's Avatar
I prime after but I also spray with filler primer and block everything. It could use a finer grit after the wheel.
Old 01-11-2015, 09:42 AM   #54
hotrod66
hotrod66's Avatar
I finally decided to cut my nice long bed side figured it's not doing me no good as a long bed. It's funny the one thing you want to be short in life never is.
Old 01-11-2015, 12:00 PM   #55
Blue666(2)
You make it look easy. Does the hand saw keep the long cuts straight?
Blue666(2) is offline   Reply With Quote
Old 01-11-2015, 02:50 PM   #56
hotrod66
hotrod66's Avatar
no i was just screwing around thought it would be a funny pic. there is a purposes for the hand saw, i used the back side as a straight edge to draw the marks on the bed as you can make it conform to the shape of the bed easy. the real cuts where made using a angle grinder with a cutoff wheel on it. now the only problem is the long bed wheel opening appears to be bigger by 2 inches.
Old 01-11-2015, 05:16 PM   #57
hotrod66
hotrod66's Avatar
I decided I am just going to shorten the front of the bed and make a medium bed. If you Guys are trying to shorten your bed, measure your one side and cut it ,keep the piece you cut out it makes a handy template.
Old 01-25-2015, 12:41 PM   #58
hotrod66
hotrod66's Avatar
Just poking along got the cab corner body work done.
Old 01-25-2015, 03:56 PM   #59
markeb01
Senior Enthusiast
markeb01's Avatar
Nice progress. I like the idea of a medium bed, especially on a fleetside. The proportions look perfect, and will drive people nuts trying to figure out if it's long or short!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 01-25-2015, 08:27 PM   #60
hotrod66
hotrod66's Avatar
Yea still toying with the idea just not shure yet I still have to lengthen the frame. I have also located a nice short fleet bed . I may just save this bed for my other truck that's all apart as well. Before I Was not able to find a bed that was nice enough to start with I have 3 beds but all a rough,so hopefully the 4th time is the charm.
Old 01-28-2015, 06:58 PM   #61
hotrod66
hotrod66's Avatar
Finished the back of the cab mud work just need to spray with etch primer and then some filler primer, then block it out.
Old 01-28-2015, 09:40 PM   #62
hotrod66
hotrod66's Avatar
Well got some etch primer on the cab looks funny in the pic due to the paint isn't dry for 1 and 2 it's over Bondo which acts like a spuge and sucks up a lot of paint.
Old 01-29-2015, 09:05 PM   #63
hotrod66
hotrod66's Avatar
Well finally popped out all the old seam sealer and ground back to bear metal. I dug my nice gmc hood out of the mower shed. Painted the inside of the cab corners and lower part of the cab with por15 .i cut a massive hole in the cowl to get to the inner seam to reseal it.
Old 02-01-2015, 09:38 PM   #64
hotrod66
hotrod66's Avatar
More dang body work! Pulled some dents and slung some mud on the roof.
Old 02-02-2015, 09:18 PM   #65
hotrod66
hotrod66's Avatar
Not much t report just pulled the fresh air vents out and striped them so I can blast and paint them
[ATTACH]1358365[/ATTACH]
Old 02-02-2015, 09:57 PM   #66
Blue666(2)
Do you need to replace the gasket around the flap door? I was not able to find the gasket online anywhere.
I am doing the same project and thinking i can cut a bicycle inner tube to make the gasket.
Good luck.
Old 02-02-2015, 11:03 PM   #67
hotrod66
hotrod66's Avatar
Good luck.
I managed to find them American classic truck parts on ebay has them $14 with shipping. Just fyi drill out the rivets it makes it easier, just replace the rivets with pop rivets.
Thanks and Good luck with yours buddy
Old 02-05-2015, 11:09 PM   #68
hotrod66
hotrod66's Avatar
Finished back part of roof yesterday ,today Pulled some dents on the front half and did some filler work.
Old 02-07-2015, 01:39 PM   #69
65 C20
Attachment 1348271
Attachment 1348272
Attachment 1348273
Just a thought.
Long beds had 3 stake pockets.
Short beds had 2 stake pockets.
Will yours have 2 ?
Nice truck by the way.
65 C20 is offline   Reply With Quote
Old 02-08-2015, 10:21 AM   #70
hotrod66
hotrod66's Avatar
None if I have my way with it.
Old 02-08-2015, 10:50 PM   #71
hotrod66
hotrod66's Avatar
No actual progress but I did get 2 ax15 transmissions 5 speeds for the truck.one is parts due to the fact the input shaft and idler shaft have no teeth. the other trans seams to be okay but going to overhaul it and get a adapter to mount it up to the stock bell housing.
Old 02-09-2015, 09:49 PM   #72
hotrod66
hotrod66's Avatar
Cut a giant hole in my trans tunnel or I cut the trans tunnel out don't know I guess it's how you look at it. This solved my problem of all the patches and holes from all the different shifters. Going to make a removable trans tunnel from another trans tunnel I cut out of a parts truck. then attach it with thread inserts.
Hope it makes the 5 speed swap easier.
Old 02-10-2015, 08:56 PM   #73
hotrod66
hotrod66's Avatar
Pressure washed my trans and drowned myself.tore it down really pleased with the results looks to be in good shape still going to overhaul it since I already ordered the parts and also ordered the adapter.
Old 02-11-2015, 08:57 PM   #74
hotrod66
hotrod66's Avatar
Made my trans tunnel cover from the old floor piece I had.
Old 02-11-2015, 10:26 PM   #75
3/4ton Randy
You are doing some fine work, sir. I live in Denton and I have had several run ins with people who do not appreciate our fondness for fine vintage automobiles. I have always thought I would move out to Justin or someplace like that and tell those city people to get happy...
3/4ton Randy is offline   Reply With Quote
