Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 01-03-2015, 08:45 PM   #1
pimpston65
pimpston65's Avatar
3 speed crossmember
im looking for an original 3 one the tree crossmember for the tail section,bellhousing bolts,and engine lift brackets for a 292. send pics and prices...
pimpston65 is offline   Reply With Quote
Old 01-04-2015, 01:03 AM   #2
Cruzinlow
Cruzinlow's Avatar
Re: 3 speed crossmember
I have one off a 65 that had a 292 with three on the tree, I'll send pics
1960 C10 SWB
BBW
Restoration in Progress
Cruzinlow is offline   Reply With Quote
Old 01-04-2015, 11:53 AM   #3
pimpston65
pimpston65's Avatar
sweet, awaiting pics and price!!!
Old 01-04-2015, 11:35 PM   #4
Cruzinlow
Cruzinlow's Avatar
Ok this is what I have, cross member came off a 65 c10 with a 292 and three on the tree and it will need a good cleaning. It has grind marks where I used a grinder to remove rivets. the two plates still has the revits attached and will need to be removed. If you need to see more pics let me know. i'll take 20.00 plus shipping
V.
1960 C10 SWB
BBW
Old 01-05-2015, 01:39 AM   #5
pimpston65
pimpston65's Avatar
V.
very nice, but the crossmember im looking for is for the tail section. i have the bellhousing crossmember. any chance you have that piece?
Old 01-05-2015, 07:50 AM   #6
Cruzinlow
Cruzinlow's Avatar
Wasn't sure which one I had sorry about that, don't have any others, good luck with your search.
V.
1960 C10 SWB
BBW
Old 01-05-2015, 08:20 AM   #7
pimpston65
pimpston65's Avatar
V.
thks for checking
Old 01-05-2015, 02:31 PM   #8
rickoner
That's the only crossmember that holds the transmission. Let me dig through my bolt stash. I should have the bellhousing bolts. I'm assuming that they'd be the same that was on the 283?
rickoner is offline   Reply With Quote
Old 01-05-2015, 03:28 PM   #9
pimpston65
pimpston65's Avatar
thks for the bolts, no worries. its a crossmember like the auto trans would have, i will find it im sure. thks for the awesome piece!!!
Old 01-05-2015, 09:37 PM   #10
pimpston65
pimpston65's Avatar
i think i should have asked if this is the correct trans for my application first!!! im looking for the correct trans for a K10 with 3 speed on the column and also what kind of tran is this i think its a sm318
Old 01-05-2015, 10:00 PM   #11
pimpston65
pimpston65's Avatar
another pic
Old 01-05-2015, 10:20 PM   #12
pimpston65
pimpston65's Avatar
another pic
does anyone have a tail section without the mounting "foot"?
Old 01-05-2015, 10:53 PM   #13
oem4me
I've seen those before. I think I remember someone telling me the tail shaft mounts were for early Corvettes.
Old 01-05-2015, 11:17 PM   #14
pimpston65
pimpston65's Avatar
i found this one without the "foot"
Old 01-05-2015, 11:52 PM   #15
pimpston65
pimpston65's Avatar
i think ima grind down the "foot" and bead blast it and fake it out as if it was original, thks for all the imput!!!
