Old 01-07-2015, 01:02 PM   #26
Jeepwm69
Re: Dash Pads
Originally Posted by Jaysonb View Post
Mine was blue and all cracked, l used a nice 4 way stretch vinyl, some good contact cement and a heat gun. Turned out nice. I also did my door panels to match. I'm into it for about $50.
That looks awesome. Are you willing to go into more detail? Where did you get the fabric (not sure what "4 way stretch" means)?
Did you glue one side, let it dry, then stretch and glue/clamp the other side or ???
I tried doing vinyl on an old Fiat dash when I was much younger. It looked worse when I finished than it did when I started.
Jeepwm69 is offline   Reply With Quote
Old 01-07-2015, 10:05 PM   #27
v30crewcab
v30crewcab's Avatar
Re: Dash Pads
stitch is now automotive professional interiors LLC on facebook.
But I'm still interested in what vinyl you used.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 01-07-2015, 11:18 PM   #28
jetmech85
Re: Dash Pads
I googled "stretch vinyl" and found some. Looks very interesting.
jetmech85 is offline   Reply With Quote
Old 01-08-2015, 12:23 AM   #29
Jaysonb
Jaysonb's Avatar
Re: Dash Pads
I can't fine the name of the exact vinyl that I used, but if you google 4 way stretch upholstery vinyl, you will find a bunch to choose from. Using a good quality adhesive is key. The best is Dap landau top and trim adhesive. I think the smallest amount that it comes in is a gallon though, you can spray it through any cheap paint gun. You just have to clean everything well with wax and grease remover, remove any loose stuff, on the back of my dash I took a rolock sanding disk and cleaned up the metal around the edges. Cut you piece big, start on one end, spray some glue on the dash and the vinyl, let it tack up, and press them together. Now go to the other end and do the same, but make sure that before you press them together that you pull a good stretch into it. Now flip the dash over and work your way around the sides. I had to shoot a little glue where the dash curves to the right of the gauges, but you do most of the gluing on the back side of the dash, that way the vinyl is stretched tight, and "floats" over the dash and hides any cracks or imperfections. For the defrost vents you just cut an x in the opening, shoot on some glue, and pull it around the back side nice and tight. Any glue that gets on any vinyl that shows easily wipes off with some mineral spirits.
Jaysonb is offline   Reply With Quote
Old 01-08-2015, 12:51 AM   #30
UKNOWME
UKNOWME's Avatar
Re: Dash Pads
Do you have any before pics?
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 01-08-2015, 01:23 AM   #31
slotard
Re: Dash Pads
I'll have to pick up a junkyard dash and try that. It looks amazing on yours. Are they all the same? If I want aluminum rather than wood can I use a newer dash without changing anything else? How about the gauge bezel too?
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 01-08-2015, 10:50 AM   #32
Phillip Pennartz
Re: Dash Pads
lurk
Phillip Pennartz is offline   Reply With Quote
Old 01-09-2015, 12:36 AM   #33
UKNOWME
UKNOWME's Avatar
Re: Dash Pads
Originally Posted by Phillip Pennartz View Post
lurk
1964 Chevy c10
Old 01-10-2015, 01:43 AM   #34
Phillip Pennartz
Re: Dash Pads
"lurk" another way to say I'm subscribing to this thread
Old 01-10-2015, 01:45 AM   #35
UKNOWME
UKNOWME's Avatar
Re: Dash Pads
1964 Chevy c10
