Old 01-11-2015, 12:09 AM   #1
jtrichard
17" steel chevy wheel
Hi has any one used these wheels and how did they fit? trying to use them on a 63 http://67-72chevytrucks.com/vboard/a...mentid=1271853
jtrichard is offline   Reply With Quote
Old 01-11-2015, 09:44 AM   #2
Re: 17" steel chevy wheel
Those look like the Toyota FJ wheels. I know someone ran them on a 69 model, but can't remember if he ran a spacer or not.
Found it: Member is TCB-1
Toyota FJ Cruiser rims, 17" x 7.5" wide on a 6 x 5.5" bc. I'm running a .75 spacer on them now, but may take them off when I lower it
Old 01-11-2015, 10:11 AM   #3
PGSigns
PGSigns's Avatar
Not sure on those wheels as to what they are. Easy enough to measure the back spacing. The one thing you will run into with many late model wheels is the diameter of the hole in the center of the wheel. I pulled my rear axles and turned them down on the end to 3.06 I think to allow the wheel to go over the end of the axle. My front was fine with the late model disc brakes on it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-11-2015, 10:51 AM   #4
rickywideglide
rickywideglide's Avatar
they look like late model gm wheel, center bore way to small
rickywideglide is offline   Reply With Quote
Old 01-11-2015, 01:36 PM   #5
61K10
61K10's Avatar
If they are FJ 17" wheels they have a big center hole. had them on my k10 when i bought it. the other ones as ricky said the center hole is too small. Look at how far the lug nuts holes are from the center hole edge. the FJ's are right at the edge.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
