Old 01-12-2015, 09:33 PM   #8
hatzie
Moderator
hatzie's Avatar
Re: Instrument cluster compatible?
One thing I failed to mention is the fact that the later clusters have electric oil pressure senders while your 74 has a Bourdon Tube oil pressure gauge with a copper line running through the firewall to the engine.
If you were moving from warning lamps to gauges you would already have an oil pressure sender wire. You have gauges so you'll have to route an oil pressure sender wire. You can likely utilize the open oil warning switch/lamp Circuit #31 spot in the bulkhead plug with Delphi Packard 56 male and female terminals on SXL wire. That spot should be unused on your gauge cluster truck. If you want to be "correct" about it use Dark Blue wire.
The 8900371 instrument cluster plug is obsolete and likely the terminals are as well. A terminal and wire pigtail will need to be salvaged from a 73-87 GM truck.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
