Old 01-13-2015, 08:21 PM   #11
t5noel
Re: Instrument cluster compatible?
I've examined the difference between the two. There will be two additional ground wires and one additional power wire. Can I splice the added ground wires from the one ground? I would assume the added fused power would have to come from the fuse box. There are two wires for the fuel sender. Is the second for dual tanks? Can it be left out if so?
t5noel is offline   Reply With Quote
