Old 01-13-2015, 08:51 PM   #2
Mike C
Mike C's Avatar
Re: 1972 3/4 4x4 rear end questions
This is a recurring thread. Spring centers on 67-72 4x4 is 40.5", the same as a 73-87 one ton truck. 73-87 1/2 and 3/4 ton trucks have 42.5" spring centers, the same as 67-72 2x4 trucks.
So yes, you will have to move not only the shock mounts but the spring mounts. I preferred the 72 shock mounts on my Jimmy and used them on the '86 Suburban 9.5" 14 bolt that I swapped in. The SF 14 has 3 1/4" axle tubes so I reused the 86 spring pads.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
