Old 01-14-2015, 11:20 AM   #1
Eraser475
Eraser475's Avatar
Cab Corners and Rockers
As we all know, the rockers and cab corners are going to rot out in a matter of time, and even if you fix them, you'll need to again in the future from what I hear. I have heard of people using a form of adhesive to put the panels on instead of welding. This maybe the dumbest thing you'll read today; who know, but what if somebody made fiberglass replacements for rockers and cabcorners and used that strong adhesive to put them on? Thoughts?
Dad's: 1973 Chevy C-60 Grain Truck 366 Big Block
Dad's: 1982 Chevy Silverado 6.2L Diesel K-10
Dad's: 1987 Chevy Silverado TBI 350 R-10
Dad's: 2007 GMC Sierra Classic 2500HD SLT
Mine: 1982 Chevy Silverado 6.2L Diesel K-10
Eraser475 is offline   Reply With Quote
Old 01-14-2015, 11:44 AM   #2
cfan10
cfan10's Avatar
Re: Cab Corners and Rockers
At least we wouldn't have to worry about the rot.
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
Old 01-14-2015, 01:48 PM   #3
Hiluxxulih
Hiluxxulih's Avatar
I sprayed about a quart of that Sheep wax stuff "Fluid Film" in the pillars and cab corners to hopefully prevent that from happening .
1985 Chevrolet Custom Deluxe
4x2 , 305 v8 , 700R4 transmission
Hiluxxulih is offline   Reply With Quote
Old 01-14-2015, 04:08 PM   #4
NJ C10 Guy
sounds like a good idea. i wonder if creating tabs on the fabbed cab corner, then tack welding a tab behind the sheet metal to attach it would be better? then some filler for the gaps to close up the seams.
NJ C10 Guy is offline   Reply With Quote
Old 01-14-2015, 04:37 PM   #5
95 S_Trucker
95 S_Trucker's Avatar
I used epoxy on the patch panels on my 85. I would not recommend it. Every single seam had hairline cracks in it. These old trucks flex too much in my opinion. If I had to do it all over, I would have had them welded in.
I did the repairs before I had a welder, and now I have one.
95 S_Trucker is offline   Reply With Quote
Old 01-14-2015, 05:48 PM   #6
72bowtiestepper
Unless they are welded all the way around, cracks will form and rust will follow. Cut out all rust, cut cab corner to fit, weld in 100%, do bodywork, paint, then hope they last !
72bowtiestepper is offline   Reply With Quote
Old 01-14-2015, 10:21 PM   #7
NJ C10 Guy
Oh i agree that's the way to do it. I was just adding onto the idea. i guess if it was that easy, people would already be doing it!
Old 01-15-2015, 02:11 AM   #8
rich weyand
rich weyand's Avatar
My bro's in aviation, has been for decades, so I use a lot of aviation type stuff. Very high quality products.
To stop rust in the tailgate, rockers, cab corners, the best thing to use is ACF-50. Skygeek.com has it.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 01-15-2015, 08:40 AM   #9
72bowtiestepper
Thanks...will have to check out that product.
Old 01-15-2015, 09:32 AM   #10
86c20
86c20's Avatar
panel bonding adhesive. i have used it on many cars and trucks as long as there is no foce on the paniel it works great. plus it is water tight unlike bondo and fiberglass unsealed. sandable and paintball to. also has more flex to it. but still welding is best this is second form what i have found
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 01-15-2015, 11:19 AM   #11
Keith Seymore
Keith Seymore's Avatar
Agree. I used the panel adhesive when I did cab corners and a place behind the LR wheel on my truck.
It's been 5 years now and they have held up fine, with the exception of the LH cab corner which was hitting the gas tank shield during "twist" maneuvers and caused it to crack. I have since removed the shield to gain more clearance.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
