Old 01-14-2015, 09:56 PM   #1
billyredneckdipper
Please help. What is this part?
So had to take brake booster and master cylender off to install headers and when i did so i broke a fitting where the metal brake ling threads in well it is complety broken and cant get part out wondering if i even need this part i cant find it ANYWHERE..truck does have a fifth wheel hitch maybe was for brake lines to it??? Its the round looking thing in picturs
PLEASE ANY INPUT ASAP would be MUCH appreciated
IF ONE MAN BUILT IT, I CAN FIX IT.
billyredneckdipper is offline   Reply With Quote
Old 01-14-2015, 10:34 PM   #2
undertaker72
undertaker72's Avatar
Re: Please help. What is this part?
does that truck still have the break control , under the dash , I think what you have there is a pressure control for the trailer brake unit , the older trucks had hyd. type vrs the new truck of today being all electric , this unit you adjust the end knurled nob to gain more pressure or less
undertaker72 is offline   Reply With Quote
Old 01-14-2015, 11:51 PM   #3
70'
70''s Avatar
Brake proportion ing valve
70' is offline   Reply With Quote
Old 01-14-2015, 11:53 PM   #4
70'
70''s Avatar
Brake proportioning valve
Old 01-15-2015, 12:27 AM   #5
billyredneckdipper
So any problems with just removing it temporarily?
Thank yall much btw
Old 01-15-2015, 12:36 AM   #6
billyredneckdipper
Thank yall much btw
Old 01-15-2015, 03:08 PM   #7
70'
70''s Avatar
Define temporarily.
Old 01-15-2015, 04:17 PM   #8
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: Please help. What is this part?
My opinion.
If your not going to be hauling any loads with a trailer I would remove it and never reinstall it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-15-2015, 10:02 PM   #9
70'
70''s Avatar
Andy is correct. If you never intend to haul a trailer, or heavy loads you should be fine. You may experience a different wear rate on front and rear brakes than you have seen in the past. If by temporary you mean take it off to access another part, or to paint it, or something else then reinstall it, you wouldn't have any trouble.
Old 01-15-2015, 10:19 PM   #10
billyredneckdipper
Right on guys thank you very much it is appreciated
Old 01-17-2015, 01:49 AM   #11
Crabass
I have a question regarding the removal of this component. Wouldn't it be a good idea to do a hard braking test (in an appropriately safe place) after removing it to make sure the vehicle won't try to swap ends? I think I'd want to make sure of that any time a change was made that might affect the brake bias.
Crabass is offline   Reply With Quote
