Old 01-17-2015, 09:53 PM   #1
Popcorn W
Popcorn W's Avatar
Re: Rag Joint rebuild question
Originally Posted by dougf View Post
I bought the same thing from autozone and rebuilt my 66 C10 rag joint in about thirty minutes. Worked great.
Thanks!
Originally Posted by franken View Post
There was a post on some forum that said rebuilding rag joints is a bad idea since it torques on the rubber and the bolt will loosen. Might look into an early XJ steering shaft swap to eliminate the rag joint.
That story about a retired GM Engineer saying that? I'm thinking as long as the nuts are Ny-Lock nuts it should be fine, but I'm no engineer either.
Popcorn W is offline   Reply With Quote
