70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Seat Belt Repair kit
The seat belts on my 72 don't retract so where I got them apart it turns out someone already had run at them trying to fix them and it didn't work. I need the round plastic pieces and one spring and one bolt. i checked a couple of vendors sites and haven't found a repair kit listed. Does anyone know of a vendor who sells repair kit, Failing that i guess i'll have to scour the wrecking yards or see if I can find some in the For Sale section.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " In the end, we only regret the chances we didnt take " " Time is the only currency we spend without knowing the balance, use it wisely ." .. |
Re: Seat Belt Repair kit
Bump
![]() Join Date: Jun 2014
Yeah I just bought a used set of seatbelts from a 72 and if fully extended out they don't want to retract. They get stuck. I was wondering myself if they can be adjusted. There is a Philips screw and bolt holding the roller in place.
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559 |
#4 | |
Could you maybe harvest what you need from these? http://pages.ebay.com/link/?nav=item...508947&alt=web http://pages.ebay.com/link/?nav=item...752464&alt=web
![]() Join Date: May 2010
Here are a couple links to previous threads that may help.
http://67-72chevytrucks.com/vboard/s...d.php?t=584809 http://67-72chevytrucks.com/vboard/s...d.php?t=627186 http://67-72chevytrucks.com/vboard/s...d.php?t=627184 There were apparently 2 different retractor mechanisms made. I've also seen 2 different floor brackets and 2 slightly different boots. |
Thanks for the links guys. I am getting educated here and can see getting the right parts for my specific application can be difficult.
If you figure out what part you need, let me know and I will pay it forward and let you have them. (Just pay shipping)
I'm pretty sure I have a couple taken apart in my garage. I can check this week end if you are interested.
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten. |
Thank you very much. I know what i need. I need 2 clear plastic sleeves and one spring. My both plastic sleeves were broken and one had been held together with duct tape and put back together. The other clear plastic roller was in pieces when they were taken apart.
I will check this weekend.
US Army Veteran
![]() Join Date: Nov 2008
Are these the ones I sent last year? If so, please accept my apologies. I thought I had included everything.
I have a couple of spare retractors here, if Acorn doesn't, and would be happy to get them off to you.
1972 C10 Highlander - The making of a daily driver |
Thanks for the post. You didn't send me belts you just sent me a cover which I received and used on different truck.
#12 | |
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
#13 | |
US Army Veteran
If you find you are still in need, let me know.
Good info to have, and it explains my observations! Thanks.
#15 |
Irvin is the other supplier.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have all original numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#16 |
Here is the part I require. If anyone knows where i can get one id be so grateful. It is the passanger seat belt sleave.
zibs71 |
#17 |
#18 |
Thanks for the parts offers guys but I was told about this place in Texas that does seat belt restoring. After trying different used parts aboard member sent his there and they did a super job restoring everything.
http://www.ssnake-oyl.com/mm5/mercha...tegory_Code=RS
#19 |
Already Gone
here is a better pix I hope. Thanks!!! zibs71 |
#20 |
Already Gone, so are you going to send your seat belts to be restored or would you still like me to look for the parts?
#21 |
#22 |
No problem. Keep us posted and let us know how they turn out.
#23 |
Will do for sure.
#24 |
I have a question about seat belt rebuilding. The plastic shroud that goes over the entire belt and mechanism, do you feed the belt down through it before you reassemble the belt retractable pieces, or is there a trick to getting it on after you have the belt all put back together? The buckle is much wider than the opening of the shroud. Not sure here and looking for tricks or advice. Thanks
#25 | |
![]() Join Date: Dec 1999
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
| Bookmarks |
