Old 02-06-2015, 06:23 PM   #1
pontgta
pontgta's Avatar
Suburban and truck frame
I would like to eventually replace my font crossmember and suspension parts... Found a suburban front end for cheap, so i thought about powdercoating while i can still have mine on. Is the a difference... I know the rear is different
pontgta is offline   Reply With Quote
Old 02-06-2015, 06:43 PM   #2
greg64
greg64's Avatar
Re: Suburban and truck frame
I can't swear to it, but I think the front crossmember and a-arms are the same. I used the parts from an 81 suburban to give my 64 suburban disc brakes. Pretty much a bolt-together affair.
I did the same as you, sand blasting everything, and replacing every ball joint and bushing while it was all apart. Boy, that new front-end is tight!
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 02-06-2015, 11:42 PM   #3
jetmech85
Yes, I put an '89 Suburban 1500 crossmember, suspension, spindles and brakes on an '84 C-10 frame with no problems. Even gave me the 1.25 inch rotors.
jetmech85 is offline   Reply With Quote
Old 02-06-2015, 11:49 PM   #4
pontgta
pontgta's Avatar
That is what i was hoping to hear.. Thank for the replies
Old 02-07-2015, 10:06 AM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
better check ore into that... I wanted to put a bur trailer hitch on a pickup and it was too wide but again this is the rear we are talking about
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-07-2015, 11:54 AM   #6
jetmech85
Yes, the rear part of the frame angles downward making the hitches different. Also the gas tank area, rear spring hangers and body mounts. It would be safe to say Suburban frames are different from the transmission crossmember back.
Old 02-07-2015, 07:44 PM   #7
1774btcrew
1774btcrew's Avatar
The front is the same from pick up to suburban
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
