Old 02-11-2015, 04:26 PM   #1
Hantke
Re: 454 v8
Okay, I'm still debating if I want to cut into the firewall or not, it seems like a good way for me to mess something up. Maybe I should be looking for a SBC for this truck and wait for my 63 for the BBC swap. That's going to be the one I take extra time on to make everything perfect as it will be a daily driver build, the 66 is my tinker toy which is being built as a work truck.
Thank you for the great info though!
2004 Sierra 2500HD - New DD / Work truck
2006 Suzuki GS500 - rebuilt after wreck (summer DD)
1966 Chevy C20 - Winter Project / Future work truck build
http://6066gmcclub.com/forum/showthread.php?t=48548
2008 Lancer GTS - DD / Parts getter - Sold
Hantke is offline   Reply With Quote
Old 02-12-2015, 12:10 PM   #2
1strong63
1strong63's Avatar
Re: 454 v8
i use poly performance mounts, just have to cut a bit the chasis rails to make them fit properly. with tall valve cover and milodon oil pan clearance is ok anywhere.
Even if the engine is sitting a bit higher for me, i'd like it lower to get a better angle for my driveline.
I drill new holes between the two available position on my chassis to get the engine as back as i want.
When i replace the cab mounts and put the cab back square to the chassis all came pretty straight and i have a bit more room on the PS of the cab for the cab heater hoses through the firewall.
didn't know what headers use anyway.
1strong63 is offline   Reply With Quote
