Old 01-16-2015, 03:55 PM   #1
kevinr1970
Tahoe Limited questions
I just picked up 2000 Tahoe limited (88-99 body style in case that is not implied ).
I read that the Limited's have the body mounted 2" lower on the frame than on the 4x4's, but are all 2-wheel drive Tahoes/Yukons the same thing, or is the body 2" lower than a 2-wheel drive also?
If some one has a Limited that has not been lowered, can you give me a measurement from the center of the wheel to the edge of the fender well. I am pretty mine has been lowered but I am not sure how much.
I know the rear has at least a shackle, but it is very long. The rear spring has a negative arch, and it is much higher in the back than the front (slopes down from rear to front) so I am thinking it is shackle and no hanger?
Anything I need to look out for or need to know?
Thanks!
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 01-27-2015, 04:24 PM   #2
kevinr1970
Re: Tahoe Limited questions
No one?
2000 Tahoe Limited
Old 01-27-2015, 04:39 PM   #3
Tom
driving is in my blood
Tom's Avatar
I've never heard they were lower in any way from the factory. As for the shackles and hangers you'd have to compare to a stock set or get someone to measure their hoe for you.
Old 01-27-2015, 05:48 PM   #4
1badgmc
1badgmc's Avatar
Yeah, beyond everything that the Limited package gives it, it's the same as any other 2wd 4 door Tahoe/Yukon.
Old 01-28-2015, 01:29 AM   #5
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I do believe the Tahoe Limited has the same suspension as the Z56 Police Package Tahoe. I have a 1999 Z56 Tahoe and part of the Police Package is the front end is lower than a stock Tahoe,and I think its 3 inches. I have all the Z56 Tahoe Specs at home and will confirm on here tomorrow. The biggest difference between the Limited and the Z56 Tahoe are the tires/rims. The Limited runs 16's and the Z56 run P235/70R15's and GM's reason for that was after the demise of the 94/99 9C1 Caprice with the Police Package a lot of Police Departments had 235/70R15 tires stock piled from the Caprices and they could be used on the Tahoe. I would love to get a 1999/2000 Tahoe Limited and have looked over the years but the ones I found were miled out and the sellers still wanted big money for them.
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 01-28-2015, 04:07 PM   #6
kevinr1970
According to Wikipedia (I know...) and the best I could come up with through Google (which might just be repeating what is on Wikipedia?), "Other notable features of the Tahoe Limited included the Z60 high-performance chassis package (commonly known as the police package) which places the body of the vehicle 2 in (51 mm) lower than the 4WD Tahoe...", but I would think that is the same as all 2-wheels drives?
http://en.wikipedia.org/wiki/Chevrolet_Tahoe
I have seen it mentioned as both the Z60 and the Z56 package too?
Already Gone, I would love any info you have!
About the tires, is that something that is documented someplace, or is it word of mouth? I ask because I read on one site that the reason for the Limited was a federal or police order got canceled, leaving GM with a run of these rides and no place to dump them. So they made them fancy to get rid of them. And the number's I read were (always from my friend/uncle/brother that worked at a dealer at the time...) 7,500, 8,xxx or 22,xxx units produced?
2000 Tahoe Limited
Old 01-28-2015, 07:33 PM   #7
Already Gone
I don't have a lot of time until the weekend but found a pic I had of a Tahoe Limited doing Police work. In the attached pic a Tribal Police Dept. from New Mexico ordered 50 Limiteds to use as police cars. The black and white was used by the Beverly Hills PD.
Old 01-28-2015, 08:06 PM   #8
kevinr1970
Cool, I appreciate anything you have, when you have time!
2000 Tahoe Limited
Old 02-12-2015, 03:10 PM   #9
kevinr1970
I sent member Keith Seymore a message and here is what he had to say:
"I happened to be the Program Engineering Manager for the Police Tahoe (as well as the Denali and Escalade) starting in 2001 and 2002 model years. Unfortunately I've probably forgotten more than I remember.
One thing I can say for certain, though, is that the relationship between the body and the frame is the same as all other Tahoe models. The reason is that there is only so much space between the frame and body to allow fuel lines and electrical harnesses to pass through; try to alter that arrangement and there would be interferences all over the place.
I think someone saw the verbiage about "the body is 2 inches lower" and interpreted that as a change between the body and frame, rather than lowering the overall vehicle 2".
So these may have been lowered suspension wise, the bodies were not mounted lower on the frames.
Also, member Mr_Shamrock took some measurements for me of a stock Limited and he said his was 19.5" in the front and 18.75" in the rear, "BUT it is parked at a weird angle right now". I measured mine at 17" front and rear. Just wish I knew what was done in the front to lower it as it all looks old/stock?
I have 20's now, but would like a different style wheel; one with a machined lip! If I am going that direction I might go 22's and then lower the truck another ~1" to maintain ride height, but tuck the wheels a little more.
2000 Tahoe Limited
Old 02-12-2015, 03:48 PM   #10
bowtieguy79
Ephesians 2:8
bowtieguy79's Avatar
I like these Tahoes. My brother has been looking for a clean one for a couple of years now. He passed one up in 12, but found this one, just over an hour away from home. He got it just last week.
They def have a nice stance, a little hard to find tires that are wide enough for the stock rims to.
bowtieguy79 is offline   Reply With Quote
Old 02-12-2015, 06:19 PM   #11
iluvmy72
What rims are these on the Beverly Hills Tahoe? I want them!!!
iluvmy72 is offline   Reply With Quote
Old 02-12-2015, 06:30 PM   #12
1badgmc
1badgmc's Avatar
Those are the 454SS/Sport wheels.
Old 02-12-2015, 06:33 PM   #13
iluvmy72
Did they come in 6 lug? If so how hard to find are they? They are sexy.
Old 02-12-2015, 06:47 PM   #14
1badgmc
1badgmc's Avatar
5-lug only unless you want to travel down to South America and see if you can score a set.
Old 02-12-2015, 08:18 PM   #15
kevinr1970
Wow! A Tahoevalance!
2000 Tahoe Limited
Old 02-12-2015, 09:48 PM   #16
1badgmc
1badgmc's Avatar
Yeah, they got all kinds of goodies down there. Note the tri-color taillights. Also note the quarter window in the rear doors to allow space for the windows to roll all the way down. That's something the 4-door Tahoes and Yukons desperately needed here so you could roll them down more than 6 friggin' inches.
Old 02-12-2015, 10:00 PM   #17
Mr_Shamrock
They definitely sit the same as the 2WD Tahoes, I replaced a 99 2WD Tahoe with my 2000 Limited and briefly had them both and they were the same. Here is mine...
LifeTime GM guy. Current collection...
2006 Z-71 Suburban
1985 C-10
1990 Suburban
1966 C-10 (me & dad's project)
Mr_Shamrock is offline   Reply With Quote
Old 02-12-2015, 10:02 PM   #18
iluvmy72
the factory workers probably make these for themselves
Old 02-12-2015, 10:15 PM   #19
Already Gone
Here are Z56 specs from the brochure.
Old 02-12-2015, 10:16 PM   #20
Mr_Shamrock
Sorry about the weird angle thing I was in the process of doing the intake gaskets when you asked for the measurement so I couldn't move the truck and it was parked in my driveway where there is a weird dip on one side. If you still need a more exact measurement the truck is moving again.
2006 Z-71 Suburban
1985 C-10
1990 Suburban
Old 02-13-2015, 04:15 PM   #21
kevinr1970
Hey, no worries, I appreciate you taking the time to do that!
2000 Tahoe Limited
Old 02-13-2015, 04:16 PM   #22
kevinr1970
Thanks for that!
2000 Tahoe Limited
