#26 |
Cruzin
Re: What do I do with my hacked 72 cheyenne?
I was told that the late beds.needed to be raised to line up right, don't no if that's true but we need pics of the frame. Also I would get the proper paper work with another frame a title, some form of ownership to be right with dmv
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
#27 | |
Not what you want to hear, but the best advice isn't always the nicest you'll hear. As others said, just get yours welded and be done with it. That's the cheapest and easiest route
______________________ www.northeastrodrun.com |
#28 |
Texas= cab= title.
#29 |
I would pull the bed or cab off and take it to a competent welding shop. They can cut out the bad and weld in a section of good frame from another donor and plate over everything. This is exactly how Open Road added 18" to my 68 frame to extend the wheelbase from 157" to 175". When I pulled the body off it looked as perfect as the day they welded it up after 62,000 miles. They were a factory dealer for GM so it had to be approved. What I am getting at is for probably around that $500 number someone mentioned earlier you can more than likely get your truck straightened out. Whole lot less work and effort than the other options. Just don't expect them to do it under the cab/bed with them in place.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
#30 |
Trixxterr according to the Highway Patrolman that use to run the Vehicle theft division in Austin the Title has to Match the Frame. I was going to use my cab off my LWB on a short frame and he told me i had to have the title to the frame i used.
#31 |
Dude,
Post some pics. From both sides of the frame as best you can. Take the bed off if need.
I just gotta get out here and do it, why? Cause nobody will do it for me... |
#32 |
Keepin an eye out
So you bought it as an advertised short bed?...Did you pay short bed money for it only to find out it was a hack job?
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
#33 |
X2, at least make an attempt. Maybe these could be used? Do you have any friends that weld? These channels may simplify the work.
http://www.cmwtrucks.com/index.php/c...long-pair.html Last edited by mechanicalman; 02-18-2015 at 09:30 PM. Reason: I see you don't weld yet. |
#34 |
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp |
#35 |
I would find a good frame and be done with it. I found my 71 Blazer frame on CL for $175 and the guy delivered it to as a roller with a HD 73 front end with disc brakes and a 12 bolt rear posi. The rear was NOT a posi but I did not care. Sold the rear and some pieces from my old bent frame and it ended up paying for the new frame...Even had good steelies on it so I just bought some 73 hubcaps. Doesn't look too bad.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#36 |
put it on the new frame and take advantage of all the newer technology in the suspension, brakes, etc.
#37 | |
1969 Chevy Long Fleet Custom C/10 (2nd owner) 1971 Chevy Short Fleet Custom C/10 (2nd owner) 2001 Chevy Silverado Ext Cab ![]() Last edited by Raider Rudy; 02-21-2015 at 02:31 AM. Reason: correction |
#38 |
Cruzin
