Re: Does the Transmission Cross Member Come Out?
Originally Posted by Gregski
Thanks, I got the bottom brackets off and all the bolts loose / off, but it just won't angle right to slide out
Try tilting the main member up on end and down on the other that should make a bit more clearance to get the member out.
If it is that tight i would trim a bit off each side.... say a 1/4 inch
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
