Old 01-15-2015, 01:46 PM   #126
SCOTI
SCOTI's Avatar
Re: My 89 CC Dually: Double Wide
For the actual lighting, I'm switching to small matchbook size 5w LED panels. I picked-up 2 (1 for the center, 1 for the rear) but after connecting & checking the light output @ the center, I felt it needed more. I spliced the 2 LED panels together & set it up that way. This improved the light output to what I felt would work well. I'm going back today to get 2 more for the rear light. Although not cheap, they aren't crazy expensive ($20ea). The thing I like is they don't generate the intense heat standard filament bulbs do.
I'll get some pics of the LED panels & post them up tonight after I set-up the rear light housing for the swap.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-16-2015, 07:31 PM   #127
SCOTI
SCOTI's Avatar
Let's see.... it's been a busy couple of weeks but it's the usual 1-step foward, 2-step back approach.
I now have a new vacuum brake pedal swapped in under the dash vs the old hydraboost pedal. Still need to get another master cylinder on & bleed the brakes again. Other mechanical items to address are the alignment & resetting the timing since the distributor was pulled a while back when the oil psi switch & fuel pump failed.
I got the seat tracks all cleaned up w/some rattle can satin black on them. Then I installed the air ride paddle valves into their respective panels after getting the panels in color w/some satin black. Once everything was dry, I installed the tracks, paddle valves, & finally the seat bottoms Sat night. My buddy is still sewing the seat backs.
Been working on other interior related stuff too.... all new power window motors (while the door panels were off). Cleaning the seat belt plastic covers (still need to blast the belts @ the car wash). Worked on the console restoration Sat night & yesterday. Got the outside in color & tonight I'll refinish the inside surfaces. It's no show truck but looks much better than it was.
My buddy worked on polishing up some stainless pieces for me while I was prepping the interior pieces. I got 6 new tires for it on Friday (sticking w/16's). The bed floor & inner surfaces have been gone over w/the DA. Still need to do some corner work, get some satin black in a few areas, get the tubs reinstalled, & seam seal it.... Then the Line-X.
Pedal....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-16-2015, 07:34 PM   #128
SCOTI
SCOTI's Avatar
Seat stuff. No airlines visible.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-16-2015, 08:42 PM   #129
lolife99
67-72 parts collector,…
lolife99's Avatar
Great update.
It's all in the details.
Keith
Convert to disc brakes.
Old 02-16-2015, 09:08 PM   #130
Hankster
Hankster's Avatar
Man, Them seats are gonna look good.
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 02-17-2015, 01:21 PM   #131
aggie91
I'm just glad to be here!
aggie91's Avatar
Anything done on the truck is progress. Seat bottoms look good!
Can you get a picture of where you are mounting the paddle switches?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-17-2015, 01:48 PM   #132
Low Elco
******n'. Better hurry, LST is comin' up fast!
Low Elco is offline   Reply With Quote
Old 02-17-2015, 01:53 PM   #133
SCOTI
SCOTI's Avatar
Yeah.... Almost too fast for the 1 man show.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-19-2015, 01:53 PM   #134
SCOTI
SCOTI's Avatar
Console finished. Turned out nice & looks better in person....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-19-2015, 01:54 PM   #135
SCOTI
SCOTI's Avatar
Last shot....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-19-2015, 02:00 PM   #136
Low Elco
Very pretty! When you rollin' out?
Old 02-19-2015, 02:13 PM   #137
SCOTI
SCOTI's Avatar
Uhmm.... Looks like it might be Tx HeatWave 2015 LoL.
I plan to hit the LST show but since it's now Thursday; I don't leave work until 5-ish; work Friday; the seats aren't done; brakes still haven't been re-bled; no alignment yet; & no continuous local driving for shakedown issues.... a 4hr drive isn't in the cards (not for lack of trying).
Add to that there's supposed to be some rain the the forecast beginning tomorrow. So, I'll hit the road in my 90 & assume my standard role of spectator.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-19-2015, 02:22 PM   #138
68Timber
I know the pieces fit
68Timber's Avatar
Very nice! Is that a repop stainless trim ring on the console? It looks new.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-19-2015, 02:40 PM   #139
SCOTI
SCOTI's Avatar
OEM. Straightend out the few relatively mild bends on the ring & flattened the retaining tabs. Cleaned a few rough spots (slight pitting) w/some 400 & Windex. Then it was lots of scrubbing using 0000 steel wool & the edge of a paint stir stick.
Since the trim ring turned out nicer than anticipated, I added the stainless hardware & did some rattle can bed-liner for the interior surfaces to add a little more detail.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-19-2015, 04:37 PM   #140
Jonboy
Slots go on anything!
console looks excellent! Wanna do a couple more?
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 02-20-2015, 09:52 AM   #141
BigMike608
BigMike608's Avatar
console is very nice!
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop
BigMike608 is offline   Reply With Quote
Old 02-20-2015, 10:28 AM   #142
aggie91
aggie91's Avatar
Looks good Scoti, We are missing out on LST again this year, work has me headed to Milwaukee for a week and I leave out Sunday. Just too much for one weekend.
Karl
The LST Challenge:
Old 03-04-2015, 09:51 AM   #143
D.FENS
Most people want to add hydroboost, you deleted it.
Was it one of those the simpler it is, the better it works things?
D.FENS is offline   Reply With Quote
Old 03-04-2015, 12:48 PM   #144
SCOTI
SCOTI's Avatar
More about the clutter. The 'clean' looking kits are expensive. Mine was leaking everywhere & had no reserve if the motor shut-off so everything needed replacing. It was much cheaper to go vacuum & they can be cleaned up nicely w/o spending a wad of cash.
I 100% agree Hydraboost is the way to go for max braking effort. But, I only plan to haul me & possibly some buddies around from time to time. Max load will be my open single car hauler beind it so the HD vacuum set-up will get it done.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-04-2015, 03:19 PM   #145
D.FENS
In the same boat myself, and was looking for a way forward. Thanks.
Old 03-04-2015, 03:40 PM   #146
slimneverdies
slimneverdies's Avatar
I've heard this statement before about hydroboost "had no reserve if the motor shut-off" issues. Whats the difference with vacuum when the motor shuts off??
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 03-04-2015, 05:52 PM   #147
SCOTI
SCOTI's Avatar
Both systems should have a 'reserve' that allows 1-2 more brake applications before they no longer provide additional boost.
For vacuum app's, if the booster diaphragm (the reserve) goes bad you typically know because the pedal gets rock hard (even with the motor running). For hydraulic apps, the hydraulic reserve reservior can leak internally which allows bleeding the pressure back into the hydraulic system (back to the pwr steering pump). You don't notice this UNTIL the motor is no longer running & then you notice it real fast!
I learned this tid-bit of info after exiting the highway to get gas & the truck died on the ramp. I hit the brake pedal & it was like I wasn't using brakes @ all. To be fair, it was more than just this as the truck had ZERO rear braking so I was relying on just the 2 front rotors to stop 5500lbs @ 50+mph. At the time I didn't know the rear brakes were non-functional (which is odd given it had recently been inspected). Lets just say I went through a 4-way stop @ still about 20mph. I was super lucky traffic was very light.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-06-2015, 01:17 AM   #148
gearheads78
gearheads78's Avatar
Looking good man
gearheads78 is offline   Reply With Quote
Old 03-08-2015, 10:02 AM   #149
SCOTI
SCOTI's Avatar
Originally Posted by gearheads78 View Post
Looking good man
Thank you sir. Your's up & going or still sorting through stuff?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-09-2015, 09:58 PM   #150
gearheads78
Trying to organize and clean up the shop to increase productivity. Sick and tired of working in a cluster f@#%. Also just changed my bother in laws clutch on the floor last week. Granny 4 speed. I'm getting too old to do that crap on the ground like I used to. Lift is going up too.
