Old 08-11-2013, 06:35 AM   #1
vannatta20
vannatta20's Avatar
LS carburetor intake using a stock DBW throttle body?, pls help
I have an idea and want to know if its possible to do. I want to get a LS carb intake with EFI bungs and mount a stock DBW 78mm throttle body off an 2004 5.3 intake on it. Can i mount the throttle body on it like a carb? I can fab up an adapter plate. I will probably run a speed density tune so I wont need a MAF. I can then fab up a mount to house a old school air cleaner on top of it to make it look somewhat period correct. With the DBW throttle body i can retain cruise control easily. I have hptuners and can adjust most settings to get this to work. Pls help me with inputs to get this working.
http://www.summitracing.com/parts/nal-88958675
vannatta20 is offline   Reply With Quote
Old 08-11-2013, 07:17 AM   #2
Matt Cramer
Re: LS carburetor intake using a stock DBW throttle body?, pls help
There are off the shelf adapters for that purpose, but most of them have a 90 degree bend for hood clearance, like this one:
http://www.summitracing.com/parts/edl-3847/overview/
Making a straight adapter should be petty easy, especially since you don't have to worry about throttle cables. You could probably just take a square of steel or aluminum plate and drill it with the appropriate bolt patterns.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 08-12-2013, 12:41 AM   #3
vannatta20
vannatta20's Avatar
Found this today. Mast motorsports has done it.
http://www.mastmotorsports.com/2010/...0System&id=487
Old 08-12-2013, 01:11 PM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
wow that looks restrictive...like it needs a 102mm TB.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-13-2013, 03:00 AM   #5
vannatta20
vannatta20's Avatar
a 87mm throttle body flows around a 1000 cfm from what i read.
Old 08-13-2013, 10:35 AM   #6
Wasted Income
Boosted Member
Wasted Income's Avatar
That's pretty slick. I like it.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 08-13-2013, 12:26 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Weird, my post disappeared. Few companies have done it, I like the idea but it also requires going with an SD tune.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-13-2013, 12:37 PM   #8
Wasted Income
Boosted Member
Funny...that's the same reason I DO like it.
Turbo diesel
Old 08-14-2013, 08:58 PM   #9
dkauffman05
dkauffman05's Avatar
WOW! Can't believe this came up . I always wanted to do this but with dbc t.b. just never took the plunge.
dkauffman05 is offline   Reply With Quote
Old 08-15-2013, 10:05 PM   #10
Blackpony
Blackpony's Avatar
That looks cool as hell! But I would rather stay with a maf tune and not SD..
Blackpony is offline   Reply With Quote
Old 12-18-2014, 02:26 AM   #11
yossarian19
I know it's an old thread, but
did anyone find a cheap / easy / crafty way to mount a standard air cleaner on the 4" OD of an LS throttle body?
I'm trying to wrap my mind around the parts / pieces available and what it would take to put a stock TB on a Victor Jr. intake, then put an air cleaner on it... My junk already runs, mind you, I just want it to look like something.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 12-18-2014, 08:01 AM   #12
dkauffman05
I'm headed in that direction . I've mage my bottom adapter from aluminum. Haven't got to the air cleaner adapter yet but I have some ideas soon to come.
Old 12-20-2014, 12:24 AM   #13
yossarian19
The part to adapt the 4-bolt DBW throttle onto the 4150 type flange is available on ebay.
Doesn't do me any good, using a Gen III 3-bolt throttle body, but the plate isn't too hard to make I don't think.
To get the carb type air intake onto the Gen III / Gen IV throttle body is a small trick.
The TB's are 4" O.D., most air cleaners are 5 1/8".
McMaster sells 1" long sections of 4" ID / 4 1/2" OD aluminum for under $10. If you have a lathe or a nearby and reasonable machinist, this could be turned on one side to 4 7/32" ID. Emery cloth the outside of the TB until this tube is a tight fit (but doable with a plastic hammer, say) and tap it on to the TB, leaving the lathe-turned side up & exposed 1/4 - 1/2".
Then you are just a $10 carb adapter away from running an old school intake on your LS.
I haven't measured how much meat is on the TB to see if it could be opened up for the carb adapter without the collar on it. I kind of doubt it; it would need almost 1/8" of metal to spare in the wall thickness.
The only other detail I can think of is needing some sort of support for the air cleaner stud. I guess you could cross-drill the collar & put a piece of bar across the diameter, that bar itself being drilled for the carb stud, but this is starting to sound ugly.
"Over my head"
Old 12-20-2014, 07:20 PM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Maybe a few mm's if your lucky trying to bore it out. Thats why the aftermarket (i.e. Nick williams) TB's came alone. There aren't a ton of good options for the dbw 78mm TB without going to something like the xdrive (that thingy that lets u run the newer style dbw tb)
Old 01-08-2015, 10:41 PM   #15
dkauffman05
Got mine done but it'd dbc
Started with an aluminum Poston on the lathe
Done
Old 01-08-2015, 10:43 PM   #16
dkauffman05
Done
Old 03-17-2015, 10:05 PM   #17
kvn1011
Kvn1011
kvn1011's Avatar
wow!! nice job!
kvn1011 is offline   Reply With Quote
