#1 | |
Re: Best 6 lug axle for AD Suburban axle swap.
1959 Fleetside Big Window Long Box Standard Trim soon to be Deluxe 1953 GMC Carryall Suburban |
#2 | |
Before: ![]() Check angle: After: Painted with SPI epoxy primer: Brake backing plate mod: Before: Donor plate with correct style of e-brake connection cut out and ready to weld in: Done: Epoxy primered: I also had an issue when buying new brake drums for this axle. I ended up buying Jeep Waggoneer drums and having a machine shop enlarging the center hole and drill out the lug holes a touch larger. Perfect and relatively cheap option. Btw, I had new 3.54 gears and a new Trac-Loc (posi) put in this rear along with all new bearings. All parts came from Tom's Differential and I had it assembled by the guy in town with the best reputation for setting up gears. He charged me $150 for the labor. Last edited by roger55; 03-28-2015 at 08:42 AM. |
If you want disc brakes, look into a Chevy Colorado, GMC Canyon 4wd.
Another one is the 95 and newer Toyota Tacoma. Again, you'll have to cut and weld in spring perches. Last edited by whitedog76; 03-28-2015 at 09:10 AM. |
#4 | |
