Old 03-28-2015, 08:26 AM   #1
roger55
roger55's Avatar
Re: Best 6 lug axle for AD Suburban axle swap.
Originally Posted by beanyard View Post
Would the same years but GMC be better because weren't they leaf suspension? Instead of coils.
My '65 GMC Dana 44 had leaf suspension but the perches need to be relocated as they are about 1/4" off on each side. No big deal to cut them off and get another set and welded on.
Before:
Check angle:
After:
Painted with SPI epoxy primer:
Brake backing plate mod:
Before:
Donor plate with correct style of e-brake connection cut out and ready to weld in:
Done:
Epoxy primered:
I also had an issue when buying new brake drums for this axle. I ended up buying Jeep Waggoneer drums and having a machine shop enlarging the center hole and drill out the lug holes a touch larger. Perfect and relatively cheap option.
Btw, I had new 3.54 gears and a new Trac-Loc (posi) put in this rear along with all new bearings. All parts came from Tom's Differential and I had it assembled by the guy in town with the best reputation for setting up gears. He charged me $150 for the labor.
roger55 is offline   Reply With Quote
Old 03-28-2015, 08:59 AM   #2
whitedog76
If you want disc brakes, look into a Chevy Colorado, GMC Canyon 4wd.
Another one is the 95 and newer Toyota Tacoma.
Again, you'll have to cut and weld in spring perches.
whitedog76 is offline   Reply With Quote
Old 03-28-2015, 09:20 AM   #3
beanyard
Before:
Check angle:
After:
Before:
Done:
Epoxy primered:
Wow. Thanks for the detailed info.
1959 Fleetside Big Window Long Box
Standard Trim soon to be Deluxe
1953 GMC Carryall Suburban
beanyard is offline   Reply With Quote
