Old 04-08-2015, 09:10 PM   #1
truckdude239
truckdude239's Avatar
speedo help
Hooked up my dolphin gauges but my speedo off the computer at idle not moving it pegs at 145 mphs and moving at 20 mph 8ve followed the calibration steps hasnt helped have not called dolphin yet do i need to tap off the vss at the transmission?
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 04-09-2015, 01:05 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: speedo help
What input does it want? The vss is a 4k signal I belive, if the gauges expect different, it won't read properly.
Certain changes can be made in the tune as well if the gauges don't have variable input.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-09-2015, 08:02 AM   #3
truckdude239
Re: speedo help
i do not know whqat the gauge wants as its not in the book and there customer support is not that great, right now i have it hooked to the computer wire and it wont read pegs 145 not moving and sit at 20 moving off the computer wire, i've done the calbartion the book says but it did not help
David fuller
2000 Tahoe 5.3l 378
Old 04-09-2015, 08:24 AM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: speedo help
Here is some info for you. I hope it helps.
http://www.docskustom.com/pdf/dolphin_install.pdf
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-09-2015, 08:34 AM   #5
truckdude239
Re: speedo help
Thats the book i have
David fuller
2000 Tahoe 5.3l 378
Old 04-09-2015, 09:07 AM   #6
Andy4639
Old member
Andy4639's Avatar
Re: speedo help
I found this to. Maybe it will help. They have no tech support at all on the website which would bother me if I had their product.
http://www.alanhorvath.com/54chevy/dolphingauges.php
This is a link off the post.
http://www.alanhorvath.com/54chevy/c...o_adjust_4.jpg
This is why I went with www.speedhut.com
GPS no calibration.
Old 04-09-2015, 09:10 AM   #7
truckdude239
Re: speedo help
those dont help as mine is the one touch speedo it doesn't have the pin switches
David fuller
2000 Tahoe 5.3l 378
Old 04-09-2015, 06:13 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: speedo help
Did you look at this one?
http://static.speedwaymotors.com/pdf/910-97710.pdf
They have some explantation on how the pulse signal is made. Its a bit confusing but it looks like which wire is hooked up determies the rating. I see 4,8,16k pulses being possible if I read this right.
Otherwise in the "speedometer" tab in HP Tuners you can alter the VSS output signal to 8 or 16 to match the gauges. Whoever did your tune should be able to make this change in about 28 seconds if his fingers are all broken.
Old 04-09-2015, 06:38 PM   #9
truckdude239
Re: speedo help
Ill look at it problem is tune was a mail oder tune
David fuller
2000 Tahoe 5.3l 378
