Old 04-10-2015, 02:54 PM   #26
truckster
truckster's Avatar
Re: Help - Found something in my oil pan
Originally Posted by NTIMID8R View Post
How long have you owned the truck. Could be part of a previous failure. A quick patch job and sell it kinda thing.
That would be my guess as well. Some previous owner had a timing gear fail and replaced the timing set without removing the pan. The oil pickup won't pull that in, so it's no harm - no foul. It just leaves you scratching your head.
truckster is offline   Reply With Quote
Old 04-10-2015, 04:11 PM   #27
mechanicalman
Originally Posted by GRX View Post
^^ nailed it. Inspect the inner lower lip on your timing cover. People often bend that to heck when trying to force the cover on without dropping the pan.
I didn't even think about the lower lip being damaged, good catch.
mechanicalman is offline   Reply With Quote
Old 04-10-2015, 04:36 PM   #28
68_Step
Originally Posted by mechanicalman View Post
Those broken gear teeth appear to be all metal no nylon, in 68_Step picture.
Yes, all metal
68_Step is offline   Reply With Quote
Old 04-10-2015, 04:44 PM   #29
68_Step
Hold on now. With the pan off, you should be able to see the timing chain at least the lower gear. If it has a double roller on it, then those teeth did not come off of those gears for sure.
I am going to pull the balancer tonight and the timing cover - might as well take a peek since I am his far along.
Pan was probably leaking because the timing set was probably already replaced when the teeth broke off and the pan was not pulled. It's hard to do the timing set with the pan on and not end up with a leak.
I sure hope this is the case!
Check crank journal where the rear main seal rides. If worn or pitted, you can get an off-set seal to ride on a previously un-used surface of the crank. Make sure it goes back together with a dust cover back there.
I had never heard of an off set seal... I love this forum! Will update later tonight once I look at it again.
Old 04-10-2015, 04:47 PM   #30
68_Step
I have had it for about 10 years (2005). Other than exhaust, water pump, and tune up stuff it has run great.
Old 04-10-2015, 05:13 PM   #31
GRX
GRX's Avatar
Good call replacing the rear main seal while in there. They can easily be installed backwards so be sure the lip is installed facing front of the engine. Oil pressure exerts against the lip forcing it to seal. Also apply a thin layer of RTV between cap and block as shown in this GM service manual. Some attention to detail and you will be seep free for some time to come.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 04-10-2015, 05:53 PM   #32
jjzepplin
jjzepplin's Avatar
On the rear main seal you don't want to put the seal halves flush with the block. Leave one side about an eight of an inch out of the block. Then apply the sealant and the cap. That way the break in the 2 piece seal is not right in front of the break in the main cap. Seal will be clocked just a bit. It seals better this way.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-10-2015, 09:50 PM   #33
68_Step
The teeth look like they are from a timing gear, but luckily not this one. The current timing gears are not missing any teeth. Looks like the leftovers from a past timing gear replacement.
Old 04-10-2015, 10:08 PM   #34
jjzepplin
jjzepplin's Avatar
Yup-that's been replaced along the way. I would still check the pickup for further debris!
Old 04-10-2015, 10:26 PM   #35
Norgermish
Norgermish's Avatar
Originally Posted by WIDESIDE72 View Post
SBC engines are not "interference" engines like a lot of other (mostly 4 cyl import) engines. Back in the day, my brothers and I had several 70's GM cars and trucks that we would buy out of peoples back yards, pastures and driveways that were abandoned due to the polyester timing gears stripping out. We would drop the pan, clean the plastic teeth out of the oil pans and pickup, swap an aftermarket cam/ lifter (comp 268H was a favorite) and timing set in, button it back up and drive, or flip for a few bucks. Even sold one Malibu back to the seller for $500 profit!
For the most part you are right about the non-interference issue on chevy SB, unless it has a big cam or 2.02, 2.08 or 2.10 intake valves. Although I have seen stock 350's with bent intake valves due to timing chain issues and/or floating valves. The lower compression engines don't have the problem but the early flat tops and factory performance engines can and do bend valves because of piston valve clearances. Don't think it is an issue with this one though.
Norgermish is offline   Reply With Quote
Old 04-10-2015, 10:55 PM   #36
GRX
GRX's Avatar
Good to see yours are not the cause. Would this be a good time to point out
that those are actually sprockets and not gears? Maybe not.
Old 04-10-2015, 11:07 PM   #37
swamp rat
swamp rat's Avatar
Did you check the timing cover yet to see if they bent the lower flanges to get the cover off and on?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-10-2015, 11:56 PM   #38
buddy_1
buddy_1's Avatar
I have seen chains so loose that they wore a hole through the front cover. Since your fixing leaks and have the cover off. Check the inside of the cover for wear marks/holes from the chain rubbing on the passenger/slack side. Buddy
I know the "VOICES" aren't real but they have some great ideas.
1978 GMC Sierra Classic C25
1983 Datsun 280ZX Turbo
1997 Chevy Cheyenne K2500
1999 Polaris Sport 400
buddy_1 is offline   Reply With Quote
Old 04-11-2015, 08:29 AM   #39
68_Step
But timing gear sounds soooooooo much better than timing sprocket!
Old 04-11-2015, 08:36 AM   #40
68_Step
Will check that this morning
Buddy: Will for chain marks too
Old 04-11-2015, 11:07 AM   #41
slikside
slikside's Avatar
sub'd
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 04-11-2015, 02:12 PM   #42
GRX
GRX's Avatar
So true. Sprocket kind of makes you think bicycles.
Hate to admit it, I have gooped up a couple timing covers after bending over the inner lip to get it back on. People don't like to think about dropping the pan after replacing those stupid nylon tooth timing sets when they break.
Old 04-11-2015, 02:31 PM   #43
mechanicalman
You can get a nice, new timing cover really cheap. Cheaper at Summit but you would have to wait almost a month. You MIGHT have to stack some water pump gaskets to keep the water pump from touching, but that would not stop me. It's a good, heavy cover.
http://www.jegs.com/i/Milodon/697/65502/10002/-1
Old 04-11-2015, 02:32 PM   #44
mechanicalman
Well played, sir. (with an English accent). LOL
Old 04-11-2015, 06:13 PM   #45
68_Step
Bottom of the timing chain cover is a bit gobbered up and the inside has scratches on the right side (pass)
Old 04-11-2015, 06:33 PM   #46
mechanicalman
Not so bad, but new is so reasonable. Resist getting a chrome one, a little harder to keep sealed but not impossible, 1pc pan gasket is the key factor.
I like to put a thin smear of silicone between a chrome cover and the gasket with nothing on the engine side of the gasket, but I like to bolt it on ahead of time and tighten the bolts just enough to squeeze the silicone out of the sides then give it time to cure. You can then remove and put a thin smear of hylomar or brush on copper-coat on the engine side of the gasket (or nothing if it's a new cover) before tightening to specs.
If in a hurry, use copper-coat spray on both sides, let it dry (does not take long especially in the sun). This works best on a new cover that has never been distorted or straightened. Do not over-torque.
Old 04-11-2015, 06:42 PM   #47
leddzepp
Moderator
leddzepp's Avatar
If you use a chrome cover, scuff the mounting surface with some fine grit sand paper. It will make all the difference in the world getting it to seal up.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-12-2015, 08:47 AM   #48
68_Step
I have a Milodon timing cover and oil pan - my pan looks like it was on a rock cllmber.
Since the cover is new and not chrome do I use gasket sealer?
I have a one piece (thick front seal) Felpro oil pan gasket do I use gasket sealer?
Old 04-12-2015, 12:36 PM   #49
mechanicalman
Not on the pan gasket, unless felpro says to and I don't think they do. I'd put a tiny dab of silicone at the bottom of the timing cover gaskets where they meet the pan gasket and maybe spray copper coat on both sides of the timing cover gasket, but new cover I'm sure you could put it on dry and no leak just don't over-torque and distort it.
I just like spray copper coat LOL. It also acts as a preservative.
Old 04-12-2015, 01:33 PM   #50
GRX
GRX's Avatar
Look for a wear groove on the balancer. If so you will need a speedi-sleeve.
