Old 08-21-2014, 10:30 PM   #1
pwdcougar
pwdcougar's Avatar
Parking brake cable routing
Anyone got a picture of the parking brake cable routing? My Sub is missing the equalizer rod that on the passenger side. What does it connect to? This is the rod that is on the opposite side of the front cable adjuster rod.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 08-22-2014, 08:23 AM   #2
Franks 72
Active Member
Franks 72's Avatar
This photo may help if you can zoom in (this is 4 x4 may not be the same as 2 WD ) ?
Franks 72 is offline   Reply With Quote
Old 08-25-2014, 01:37 AM   #3
Franks 72
Active Member
Franks 72's Avatar
Found a better photo.
Old 08-25-2014, 01:44 AM   #4
vectorit
What?
vectorit's Avatar
Re: Parking brake cable routing
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 08-25-2014, 07:03 AM   #5
pwdcougar
pwdcougar's Avatar
Thanks guys!
Using photoshop I lightened up your first picture and can see that the rod hooks through a hole in the frame on the right hand side. Once the LMC parts come in it shouldn't be tough to figure out which hole.
Paul
Old 08-25-2014, 01:46 PM   #6
Franks 72
Active Member
Franks 72's Avatar
This should help. Tape "0" datum is the front of the frame rail. First hook hole (long one ) is at 77 1/2 " . Next one is at 96" . Again ,this is a 4 x 4 but I see no reason that it would be different on 2 WD. Hope this helps.
Old 08-25-2014, 05:16 PM   #7
pwdcougar
pwdcougar's Avatar
Awesome. Now that helps!
Thanks!
Paul
Old 09-01-2014, 07:28 PM   #8
pwdcougar
pwdcougar's Avatar
I can say for certain that the rear cables listed in the LMC catalog are correct for a 4WD. They match the originals perfectly.
Something weird in your picture Franks 72 your cable guides are bolted to the inside TOP of the frame rail. On my 70 they were bolted in bottom channel.
Paul
Old 09-02-2014, 12:12 AM   #9
Franks 72
Active Member
Franks 72's Avatar
Cant explain the difference. This was a Canadian truck?
My second hook is not bolted just hooks on the frame rail the same as the front.
Perhaps they changed something in the 72 4X4 ?
Old 09-02-2014, 04:28 PM   #10
WhiteWhale
WhiteWhale's Avatar
my 72 K20 pigtails were located on the top of the frame rail and were not bolted. The hook on the end of the pigtail just went through the hole and was held in place with the tension of the cable.
WhiteWhale is offline   Reply With Quote
Old 09-07-2014, 07:09 PM   #11
pwdcougar
pwdcougar's Avatar
Took a chance on the LMC cables and they were a perfect match to what was on the truck. Now the problem is that the ones I took off might have been wrong! I found the holes to mount the rear cable brackets on the top of the frame rail. My brackets were mounted on the bottom of the frame rail a few inches back. To clear the frame bracket rivets, the brackets had 1/2" long spacers. The new (and old) brake cables are too short to allow mounting on the top of the frame in the original holes.
The top photo is one of Lock Doc's from 2011 and the bottom is from my truck.
Paul
Old 09-07-2014, 08:10 PM   #12
Bigdav160
Bigdav160's Avatar
I'd say, someone rigged yours in the past
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-07-2014, 10:38 PM   #13
pwdcougar
pwdcougar's Avatar
Yep. That was my guess too. Only thing is, it was rigged before I bought it in the early 80's or I don't remember rigging it!
Paul
Old 04-10-2015, 10:58 PM   #14
bettlebob
This thread has been extremely helpful, I was wondering if anyone had pictures of how the front cable is routed and secured on a 4WD. I have a 72 K10 and the previous owner had rigged it with a 2 wheel drive front cable that was not secured and they fabricated a bracket to hold it under the truck. I got new cables from Inline Tube and would like to get it install correctly.
bettlebob is offline   Reply With Quote
Old 04-23-2015, 06:13 PM   #15
First c10
First c10's Avatar
I would also like to see a few more pictures of how you all have your e brake cables routed and/or attached please.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 04-23-2015, 09:33 PM   #16
Hotrodder350
I have to agree with Bob and I too would like to see more pictrues.
Hotrodder350 is offline   Reply With Quote
Old 05-27-2016, 08:33 AM   #17
Corey'sgotachev
Our truck is a 1970 K/10 longbed as it sits right now. When we bought it, prev owner has cable from inside cab coiled up on LF fender. Has cables from brakes dead ended-just kinda hanging there.
I'm looking at LMC and ordering "Intercable Longed 4WD", "Park Brake Cable Guide Kit", and a "Park Brake Cable Grommet".
Anything else I need?
This thread is most helpful as I am not sure exactly the routing needed.
Anyone have more words of wisdom or more pictures for a newbie?
Thanks!
Corey'sgotachev is offline   Reply With Quote
Old 09-22-2024, 01:43 PM   #18
gmc 2500 4x4
Helpful
gmc 2500 4x4 is offline   Reply With Quote
