Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 04-29-2015, 08:05 PM   #201
DWilbur
Re: Project 68 k10 LWB..aka "The Hulk"
the top picture showing the end of your tape measure move to the right about 3/4" that part of the block is where I measured from.
DWilbur is offline   Reply With Quote
Old 04-30-2015, 12:01 AM   #202
7dee2
7dee2's Avatar
Originally Posted by DWilbur View Post
I fit mine with the cab on.
Before you make it permanent I'd throw a cab on it just to be sure it's far enough forward to clear, IMO this is the biggest deal. Also a factory transfer case crossmember should set the rear height pretty close but if not you can tell with the cab on also. You kept the motor high enough and centered again using a factory crossmember (scalping the top of the stands kept the height). Your motor mount arrangement looks comparable in height to a factory clam shell style (which could be measured). FYI, my 84 K35 engine crossmember was centered in the frame. Any offset side to side would be built into the stands I believe.
Brett
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 04-30-2015, 01:15 AM   #203
First c10
First c10's Avatar
Yeah I was hoping to not have to put the cab on but probably the best. I looked at dwilbers and wasted incomes builds both have there engines in different places. Actually wasted incomes is farther forward and DWilbers is back a little ( I think) I went off the pictures referencing the holes in the frame which I believe are in the same place on all 4x4 frames. With the current stands and TC crossmembers my engine/trans is at 4* down.
Thanks for the help guys
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 05-01-2015, 03:03 PM   #204
DWilbur
info on the bump stops from ORD
http://offroaddesign.com/catalog/bumpstops.htm
Old 05-04-2015, 05:51 PM   #205
First c10
First c10's Avatar
thanks for the link. I measured my wheelbase I am almost 126" so that means it did move forward just like it looks. I may need to get the zero rates but hope it doesn't raise it to much in the rear.
GO GO!!!
Old 05-04-2015, 06:52 PM   #206
DWilbur
0 rate will raise it what the thickness of the block is.
Old 05-05-2015, 11:06 AM   #207
First c10
First c10's Avatar
Yes I noticed that..... What else can be done other than moving the spring perches back?
GO GO!!!
Old 05-05-2015, 05:11 PM   #208
DWilbur
Drill a new hole in the spring pack and relocate the axel.
Old 05-07-2015, 12:46 AM   #209
First c10
First c10's Avatar
Not sure why that wouldn't work. I may have to try it, I think I will do it when I have to shim the rear end.
I got the motor installed and measured the angle of the trans. 4*
The rear end is like at 15* going to have to think about it a little
GO GO!!!
Old 05-07-2015, 02:01 PM   #210
DWilbur
I don't worry to much about the angle of the drive shafts they are close when stock. with lifted truck it depends on how much lift. Over 6" then I would look at reworking the spring perch.
Old 05-07-2015, 03:54 PM   #211
First c10
First c10's Avatar
Well I think with the 4" flip kit it turns the rear ended up to much. I am about 11-12* upwards to much. Shouldn't they be a lot closer? Just about everywhere I have read says that. I can lower the back for the trans a little. It but not that much.
GO GO!!!
Old 05-07-2015, 07:36 PM   #212
DWilbur
I know ORD has different shackles for the flip kit. I talked to them on the phone as to what I should order and I fallowed along on their web site as they gave me the part numbers and placed the order that way. every thing they sent me fit perfect except for the steering gear brace.
Old 05-07-2015, 09:33 PM   #213
First c10
First c10's Avatar
I did the same as you. I will call them tomorrow. Maybe I have my pinion angle numbers wrong. I do know that I am 126" so it is deffinetly 1 in closer then stock.
I did get the transfer case hung this afternoon.
GO GO!!!
Old 05-07-2015, 09:38 PM   #214
First c10
First c10's Avatar
Here is a picture of the the t case with the brace that goes from the t case to the bell housing.
GO GO!!!
Old 05-07-2015, 09:40 PM   #215
First c10
First c10's Avatar
This is the header brace clearance. Looks pretty close.
GO GO!!!
Old 05-07-2015, 11:24 PM   #216
DWilbur
It's looking great. your cross member is a lot different than mine. the trany and T-case look brand spanking new.
Old 05-07-2015, 11:25 PM   #217
DWilbur
I meant to say the transmission cross member. it look like it's our of 2 wheel drive truck.
Old 05-07-2015, 11:57 PM   #218
First c10
First c10's Avatar
This is the crossmember from the 91 burb that I got the transfer case out of. It came with a transfer case skid plate. I am not sure if it is better than the 70.
The transmission is just cleaned up and painted. The TC is rebuilt by me before I even had the frame.
GO GO!!!
Old 05-08-2015, 10:15 AM   #219
7dee2
7dee2's Avatar
Really looks great! I would lower the trans/tc the little bit that you're mentioning that should help with both front & rear angles from the lift. Do you think the weight of all the sheet metal will change your angles also? Perhaps you should think about simulating the weight to make your rear end adjustments to correctly center the rear wheels, then give it the optimum drive line angle correction if it's still necessary.
Brett
Old 05-08-2015, 10:47 AM   #220
First c10
First c10's Avatar
Thanks guys for the support.
I am thinking about getting the rear axle corrected before I work on the angles. The axle needs to move back 1". I think I am going to put the bed on just to check that the rear wheel is centered before I do anything.
I thought the same thing about adding weight to the frame to see what changes... so close but still so far... story of my life SMH....
GO GO!!!
Old 05-08-2015, 12:20 PM   #221
First c10
First c10's Avatar
Since the front drive-line I have is a double carden (CV) style. Looks like I will have to adjust the front axle angle....pinion up.
Can you use a double carden (CV) on the rear drive-line??
GO GO!!!
Old 05-08-2015, 12:46 PM   #222
First c10
First c10's Avatar
ok so I just talked to ORD about my rearend situation regarding the pinion angle and the wheelbase. he said he would machine a zero rate block to move the axle back 1" and drop the pinion angle. the only issue I see is the 1" of lift it will give me. I did put 6" front shackle hangers which will give me about 1" extra lift in the front. maybe the zero rate blocks will work out. I wonder if anyone knows the difference in frame height with a 4" lift on a complete truck can some one measure for me?
GO GO!!!
Old 05-08-2015, 03:37 PM   #223
DWilbur
My nephew had a double carden on the rear drive shaft he had 8" lift and it was the only way to fix the binding of the single U joint on his blazer. I have 4 degree shims on front and back to correct the shaft angle for the 6" lift. that cool that ORD can make you 0 degree with offset.
Old 05-08-2015, 04:01 PM   #224
First c10
First c10's Avatar
Hey David thanks for the info. How did you know to go 4°? I have figured it out if I use a double carden on the rear I don't have to shim the rear at all. The front I think I will have to go at least 4°. I am going to put the u joints in the front drive line and get it mounted and doublecheck.
GO GO!!!
Old 05-08-2015, 06:00 PM   #225
DWilbur
The 4 degree shims came with the lift kit for the front springs and ordered an extra set for the rear after measuring the 4" blocks that I had ended up 4 degrees.
