Old 05-07-2015, 06:55 PM   #1
DBear
DBear's Avatar
71 Burb with a leaning problem
Ok....I have been working on this tank for some time. Just started buttoning up the 3/4 ton axle swap and the DAMN thing is lower by a 1 1/4 on the drivers side. I first thought it was the springs so I swapped them out with a set of skyjacker lift springs....and still the same problem. When I set the skyjacker springs on the axle, and the axle was sitting on jack stands, it was level! When I put the tires on and lowered them to the ground, the burb then had the lean of 1 1/4" to the drivers side again.
I have checked the following :
Tire pressure
Body mounts
Spring bushings etc...
I checked the front of the frame and it was level....and pretty sure frame isn't tweaked because I don't remember if ever leaning at all.
this one has me stumped....please help if u can!!!
DBear is offline   Reply With Quote
Old 05-07-2015, 08:36 PM   #2
argonaut
argonaut's Avatar
Re: 71 Burb with a leaning problem
Two different length shackles??
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 05-07-2015, 08:55 PM   #3
DBear
DBear's Avatar
Yeah....measured those and they are same size. This is the weirdest thing I have experienced with this rig for sure
Old 05-07-2015, 09:11 PM   #4
argonaut
argonaut's Avatar
It is weird. so with the new springs mounted and the axle mounted, but axle on jack stands, it was level? Are you sure both jack stands were extended the same amount? can you simulate this by putting it back up on jack stands? is one of your tires mistakenly a smaller size!?!?!
Is the rear axle a 14 bolt, eaton or dana 60? Did you relocate the spring perches inward to 40"? Or did you convert to later model wider hangers at 42.5"?
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 05-07-2015, 09:25 PM   #5
cdowns
cdowns's Avatar
normal chevy lean they all do it to some extant the harder they were used the greater the lean
Old 05-07-2015, 09:30 PM   #6
DBear
DBear's Avatar
Is the rear axle a 14 bolt, eaton or dana 60? Did you relocate the spring perches inward to 40.5"? Or did you convert to later model wider hangers at 42.5"?
when I had it up on jack stands....and unfortunately they were even /level, the burb sat level. The 14 bolt came out of a 3/4 ton which the perches line up. The tires measured the same as well
Old 05-07-2015, 10:12 PM   #7
Bladeboy1998
This
I forget who it is (has the polar bear suburban) I think it was his build thread he talked about the chevy lean.
Bladeboy1998 is offline   Reply With Quote
Old 05-07-2015, 10:27 PM   #8
argonaut
argonaut's Avatar
With good body mount bushings, springs, spring bushings and shackles, there is no reason a truck should lean. At least not as mush as 1"+. Unless it is actually weighted heavier on one side, or something is on the chassis is bent.
If it sat level on the jack stands then the only remaining factors are the wheels and tires.
The other puzzling thing to me is that there is no factory 3/4 ton truck (or 1 ton for that matter) with a 14 bolt that has the the same spring perch distance as a 71.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 05-07-2015, 10:30 PM   #9
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
The cab & chassis 1 tons drw have the same perch distance as the 72 body style.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 05-07-2015, 10:40 PM   #10
'63GENIII
'63GENIII's Avatar
My '63 leans about the same amount but on the passenger side. The only difference is that the front shackle on the passenger side has a little more angle. By a little Im talking within 5 degrees of the drivers side. Its driven me crazy for the last 8 years! In two weeks, Im swapping in a set of 52" springs into the front and at that time, I will make sure that the new rear shackle eyes and front spring hangers are in identical places. I can't tell you how many times Ive measured my frame with a straight edge and plumb bob only to come to the conclusion that the hanger was installed just a little off at the factory. Not sure if this is what you have going on with yours as well but its free to take a tape measure and look.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 05-07-2015, 11:39 PM   #11
bilfman
bilfman's Avatar
Could be a bent frame , hate to bring that option up. I had the same issue on a prior resto, needed a tweak on a frame machine to fix it.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 05-07-2015, 11:56 PM   #12
Mr. D
Mr. D's Avatar
Mr. D is offline   Reply With Quote
Old 05-07-2015, 11:57 PM   #13
Mr. D
Mr. D's Avatar
Check the spindles. One may have 1" drop.
Just a thought.
Old 05-08-2015, 01:57 AM   #14
swamp rat
swamp rat's Avatar
My thought is binding suspension, did you lower the driver side last with a floor jack? did you torque the U bolts up in the air or on the ground?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 05-08-2015, 02:26 AM   #15
argonaut
argonaut's Avatar
My 83 1 ton perches measured 40.5". My 73 3/4 ton measured 42.5". My 64, 66 and 70 axles measure 40". This is measured by hanging a plumb bob from each spring perch centerline to a flat level surface and measuring between them. To be fair, I never measured an axle from a cab & chassis truck.
I dont mean to steer this off topic; the reason I bring this up is because if the OP has a 1 ton axle with 40.5" spacing installed on 40" wide hangers then spring bind could be causing some problems, whether they are causing the lean or not.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 05-08-2015, 02:31 AM   #16
argonaut
argonaut's Avatar
Another thought: measure your springs from each end to to center pin. My 52" long tuff country 4" lift rear springs had slightly offset spring pins so I had to be sure to have both oriented the same.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 05-09-2015, 07:02 AM   #17
Just throwing this out there since no one has mentioned it... Could the frame be cracked at the steering box? What surface is the truck on when measuring?
The last suggestions by argonaut could make a difference.
Old 05-10-2015, 02:07 AM   #18
Mr. D
Mr. D's Avatar
One thing for sure, this is not your usual problem. Very odd.
Old 06-05-2015, 03:47 PM   #19
Mr. D
Mr. D's Avatar
Did you ever find out what the problem was?
56 Chevy step-side
68 Chevy Suburban
69 Corvette Stingray
00 BMW 325 (Daily driver)
09 BMW M3
18 GMC Acadia (Wife's daily driver)
