Old 05-08-2015, 04:53 PM   #1
WarMonger
WarMonger's Avatar
Stupid radio Problem
ok, so my radio works great......until i hit 35 mph then i dont hear any sound coming out of the speakers. Radio still has power. Looks like it is working. No sound. take foot off the gas. trucks slows down, right when it get to 35 mph and less, sound comes back on. WTF?????
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 05-08-2015, 05:13 PM   #2
cdowns
cdowns's Avatar
Re: Stupid radio Problem
i'd check the antenna
Old 05-08-2015, 05:29 PM   #3
WarMonger
WarMonger's Avatar
It even does it when I'm using a USB drive to get music. Could it still be the antenna?
1970 C20
-_--_--_- ______
1972 K5
Old 05-08-2015, 08:15 PM   #4
RichardJ
>>Radio still has power<<
By that I assume you mean the radio lights are still on. Connect a volt meter so that you can read it while you drive. Either bring two wires in from the battery or connect at the radio fuse and a ground near the radio.
For it to be so precise at 35 mph, I suspect a voltage problem. Possibly an over-voltage problem and the radio has an over-voltage protection circuit.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 05-08-2015, 08:51 PM   #5
EARNHARDT#3
EARNHARDT#3's Avatar
Sitting still slowly rev the engine through its RPM range and see if it does the same thing.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 05-08-2015, 10:39 PM   #6
1972_K5
1972_K5's Avatar
Turn up the volume....
1972 K5 CST
1972_K5 is offline   Reply With Quote
Old 05-09-2015, 12:31 AM   #7
WarMonger
WarMonger's Avatar
It does not do it when sitting with RPM's. I was thinking an over voltage is happening. It's weird. The display still shows all the same stuff. Just no sound.
Old 05-09-2015, 01:28 AM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
Think maybe you're getting some RFI from ignition components when you get into a high RPM regime? There used to be coils and capacitors and shielded plug wires to shield AM and FM signals from the hash.
Old 05-09-2015, 06:43 AM   #9
hamjet
hamjet's Avatar
x2, the wind may affecting it. turn the radio on and go out and move the antenna. (while sitting still of course)LOL...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 05-09-2015, 01:07 PM   #10
RichardJ
>>It even does it when I'm using a USB drive to get music.<<
Obviously not an original radio and also obviously not in the tuning section of the radio.
