#26 |
Re: To make a long box short
#27 |
#28 |
#29 |
#30 |
#31 |
#32 |
![]() If I can do this, so can you. Your going to have some gaps here and there, expect that. Just make sure you are good at zapping sheet metal and have a copper backing plate to fill in here and there and you will be fine. If the joint starts pulling I because of the heat by P the metal out with a hammer and dolly. Go slow, don't let the heat build up, and enjoy Your new shortened bed' Posted via Mobile Device |
#33 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Thanks for the step by step.
My truck is a short stepside. I have a long fleetside bed I want to cut down. Your pics make it less intimidating.
#34 |
Thanks. I have had a few beers so I'm going to make a better post when im able to
![]() The last pic makes it look like the bed is anted upwards however it is not. Must be a combo of paint/lighting. If you take your time with the measurements and can follow a line with a cutoff wheel anyone can do it. I'm even using an old craftsman wire feed welder from 2001 that I got from bookoo for $60 ![]() |
