Old 05-12-2015, 07:03 PM   #1
MikeB
MikeB's Avatar
Add gauges to instrument panel
Will factory gauges fit in the panel below?
Also, is there a way to install standard 2-1/6" gauges? If so, I'd like to see some how-to pictures.
Thanks.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 05-12-2015, 09:38 PM   #2
moon77
Re: Add gauges to instrument panel
I'm interested too
moon77 is offline   Reply With Quote
Old 05-12-2015, 10:08 PM   #3
mongocanfly
mongocanfly's Avatar
Oh yes...they can be made to work..but...it will take a lot of modifying..first I cut off all 4 of the idiot lights from the speedo and gas mounts on the frame in your pic. Then I cut off the brake light panel and reinstalled it and the speedo/gas ring back on the dash panel .I had to cut the reccesses from the backside of the dash panel bezel until the new gauge would fit into the recess...and then I had to grind /sand/file/whatever it took to the light green backing plate behind all this for clearance and drill holes fhru it for all the new gauge stuff to go thru.then tape up all the printed circuits that won't be used anymore to prevent a short. All this is a pain in the butt to do but once I started I couldnt turn back.. I would have been better off just gutting the whole thing but I was trying to save as much as I could and I wish I had something that looked better to go in the brake light position but I was getting tired of working on it.
Old 05-12-2015, 10:44 PM   #4
dieseldawg142
dieseldawg142's Avatar
i found it actually easy, just time consuming-especially with the wiring...
i have a few pics when i put 4 auto meter pro-comp gauges in mine.
peace of mind having functioning gauges
ground the bezel to fit the gauges
Size:  50.8 KBName:  785.jpg
cut off the 4 gauge section
re-routed the wires i need, went to the stereo shop & got a multi-plug for the gauges so i can still take out the dash
finished
dieseldawg142 is offline   Reply With Quote
Old 05-12-2015, 10:53 PM   #5
mongocanfly
Yeah ...I kinda went the long way around the barn to get there..if I did it over I would have just gut everything behind the gauges..would have been simplar.
Old 05-13-2015, 01:27 PM   #6
MikeB
MikeB's Avatar
So how did you secure the gauges to the bezel? And are they 2-1/16" diameter?
Thanks.
Mike
Old 05-13-2015, 04:41 PM   #7
mongocanfly
On my dash the bezel holes taper down from front to back.it was trial and error on cutting the back of the bezel to find where the gauge would fit tight coming in from the front side. Be careful to only cut a little at a time to get the right fit. They will kinda wedge in there when you hit the sweet spot.The gauges came with the metal stirrup that goes over the studs on the gauge back but I made some with longer legs so that they would reach the bezel.I used all mechanical gauges which is why I had to cut as much stuff as I did.electric gauges would have been simplar
Old 05-13-2015, 05:48 PM   #8
MikeB
MikeB's Avatar
OK, so you're saying you pushed them in from the front until the fit got tight, and then secured them from the back. Got it!
I just don't see how the gauges in the above pic are secured.
Mike
Old 05-13-2015, 05:59 PM   #9
mongocanfly
His are different from mine and I had to look close to see it but if you look at the back of the gauge it looks like it has 2 thumb screws on it if you look close you can see a black collar that goes all the way around the gauge and under thumb screws..I think that's what holds his...but my eyes ain't what they used to be..ha ha
Old 05-14-2015, 09:20 AM   #10
77c10
77c10's Avatar
I'll just leave this here.....
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 05-14-2015, 09:25 AM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
No the area behind won't easily accept the factory gauges.
Also the position of the gauge to idiot light, and the wire positions of the plug is different from gauges to idiots.
I was able to find and swap idiot to Factory Tach/gauges in my 78K5,below
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 05-14-2015, 10:33 AM   #12
dieseldawg142
Thanks.
as mentioned, in from the front, then the gauge carrier snugs it up tight on the back. if your careful with your grinding, you can angle the gauges a bit for better sight lines, & yup, 2 1/16
Old 05-14-2015, 12:16 PM   #13
mongocanfly
No fair 77c10...your dash makes mine look like a hack job...ha ha..yours looks great..I was more after function on mine..its just a ol farm truck anyway.
Old 05-14-2015, 12:19 PM   #14
mongocanfly
I missed his question about factory gauges...I bought a full set for mine but then realized you have to change everything for them to work so I went with auto-gage
Old 05-14-2015, 11:25 PM   #15
moon77
Nice 77c10!! that looks beautiful
Old 05-15-2015, 05:07 PM   #16
77c10
77c10's Avatar
Thanks! Jeff (bigblock73) does excellent work.
