Old 05-18-2015, 01:55 PM   #39
swamp rat
swamp rat's Avatar
Re: Ball joints?
If you don't have a service manual please get one, there is a downloadable PDF manual available on this forum.
You need to remove the outer locking hub first then then straighten the large washer locking tab and remove the large nuts that are used to preload the wheel bearings, then remove the outer bearing, then pull off the outer hub and rotor, then unbolt the hub nuts holding the stub axle, it can be stuck with rust so get a piece of wood and a hammer and work it off, then pull the axle out.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
