Old 05-31-2015, 03:58 PM   #14
jjzepplin
jjzepplin's Avatar
Re: Driveline/Joint Help Needed
This is true. Mine fit the stock front shaft (after it was lengthened). Fella at Tom Woods said the same thing about it being unnecessary. Said if you pretzel the front shaft go for it but til then you most likely will be ok. So I spent the big bucks going overkill on the rear.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
