Old 04-24-2015, 12:55 PM   #26
SCOTI
SCOTI's Avatar
Re: designed drop trailing arms
Why the fixed poly & not their swivel joints? The thickness/stiffness of the construction of your arms w/the poly bushings are going to have more binding vs OE arms/bushings.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-24-2015, 05:39 PM   #27
casey g
casey g's Avatar
Hey scoti. I understand your concerns. I'm using 3/16 material and not 1/4 like I first said. Also there swivel joints are more then twice the price. All I would have to do is order some swivel joints if these don't workout but I would like to try them first. I'm honestly thinking I'm going to be fine but you could be right.
casey g is offline   Reply With Quote
Old 04-24-2015, 05:42 PM   #28
casey g
casey g's Avatar
Started to weld one of them up today
Old 04-24-2015, 05:44 PM   #29
casey g
casey g's Avatar
Another
Old 04-24-2015, 05:45 PM   #30
casey g
casey g's Avatar
It won't let me post more then one pic at a time.
Old 04-24-2015, 06:18 PM   #31
SCOTI
SCOTI's Avatar
They're well worth the investment. Very cool design & I love the look. Kudo's to you brother!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-29-2015, 12:56 AM   #32
casey g
casey g's Avatar
More progress
Old 04-29-2015, 07:51 AM   #33
chevy2tom
chevy2tom's Avatar
I'm watching this one, going to bag it this summer. Looks awesome.
chevy2tom is offline   Reply With Quote
Old 04-29-2015, 01:14 PM   #34
Doug's68SS
I like what i see so far
Doug's68SS is offline   Reply With Quote
Old 04-30-2015, 02:02 AM   #35
casey g
casey g's Avatar
Here is one more weld picture and a picture of one trailing arm almost done!
Old 04-30-2015, 08:37 AM   #36
bbcmudtruck
Those arms look cool, and your welds are grade A!
bbcmudtruck is offline   Reply With Quote
Old 04-30-2015, 09:13 AM   #37
bigguy69
dazed and confused
bigguy69's Avatar
Nice!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 04-30-2015, 11:47 AM   #38
lowlyfec10
very nice! curious about the pricepoint on these? and do they allow more clearance with the frame for bagged trucks?
lowlyfec10 is offline   Reply With Quote
Old 04-30-2015, 03:48 PM   #39
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Very cool idea. I am not an engineer but I would be concerned with how thin the area behind the spring mount and axle kick up might be. Without having a pivoting joint in the front (like suggested above), all of the axle twisting is likely to get concentrated in this area and eventually could fail. That would be very bad at speed. Just my opinion. Either way, nice fab and welding work!
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-06-2015, 03:08 PM   #40
casey g
casey g's Avatar
I honestly see no way this will fail. If this was on a 4x4 where there is a ton Of travel I would be going a different route. But with a slammed truck trying to get a couple more inches that only has a few inches of travel with a small notch I do not see a problem. I'm confident is my welds and fabrication. But that's my opinion.
Old 05-06-2015, 03:11 PM   #41
casey g
casey g's Avatar
Both are 98% done. Just need to make a little piece to fit behind the spring/bag mount.
Old 05-06-2015, 03:12 PM   #42
casey g
casey g's Avatar
One more pic of both trailing arms.
Old 06-02-2015, 10:32 PM   #43
casey g
casey g's Avatar
well the trailing arms are done and installed.
no issues on the install and the truck drives great.
in the end the trailing arms lowered the truck just under three inches.
here are a couple photos of the install and truck afterwards.
