Old 06-09-2015, 08:46 AM   #1
Re: Brush-on chassis paint - Happy with results?
I se Masterseries because I am really sold on it and I know they actually make their product. The owner is a chemist who used to work for POR-15 and quit to start his own company when the cheapened down the product. I recommend brushing over spraying. It self levels, as far as looks goes. You will get a better coat of finish and not miss a spot. If you hit it at all, it's a good coat. With spray, and all the blow-by and various hidden angles, you tend to miss spots or barely cover others. You find out when you see the rust later on.
Old 06-09-2015, 04:52 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Thanks again K. I'll look into Masterseries. Incidentally, I called the soda blaster today. His attitude sucks so he won't be getting my business. I may end up stripping this down the hard way.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
