![]() Join Date: May 2005
292 motor mount bracket
I know that the perch for the passenger side motor mount must be the one used for the 292 and must be moved forward a bit. I have done this in the past but today while getting ready to install the 292, the motor mount bracket that mounts to the block will not fit . I am attempting to use the brackets from the previous motor a 250. Does the passenger side bracket from an original 292 have to be used also? Thoughts
Re: 292 motor mount bracket
292 pass side perch is only for a 292. nothing else works
ron |
I know the perch is but what about motor mount bracket to block?
they are all the same
ron |
There are spacers between the block and mount, also think the mount it's self is different.
Between saying and doing many a pair of shoes are worn out ![]() |
#7 | |
I decided that it seemed like I could redrill the mount and make it work IIRC, but I need to pull the correct mount off another 292 I have and check (hopefully Sunday/Monday). Anyone else? See above. |
#8 | |
ron |
Okay first is 230,250 second is the factory spacers on the 292 third is 292 block mount which is different from the 230,250.hope your happy this was driving me nuts so I went out to my shop in my boxers to figure this out
#11 | |
Not shure it's a target block made in Mexico but I took both the mounts from my factory 292 that was in my 65. previously the engine was in a 76 6x6 one ton guess I got lucky with mine.
#13 | |
The only reason I add the disclaimer that both mine are not 63-66 blocks is because I am unsure if those are different, since I don't have one. It's obviously not. Like I said, I'll try to figure it out Monday and get some pictures for you. |
Another thread I found discussing this: http://67-72chevytrucks.com/vboard/s...=493950&page=2
#15 |
Ok, I did some more research and managed to find some pictures I took.
Apparently the 230/250 right hand side mount is the one that is different. It appears you need two left hand mounts with spacers on the right hand one to make the 292 setup. I'll do some more checking when I have the stuff in my hand and report back... |
#16 | |
#17 |
Hey thanks everyone, Found a pair of left side brackets in a box along with one spacer so am down to finding one spacer to finish 292 install. This is one outstanding forum, thank you all for your input. Anyone know where I might find one spacer?
#18 |
you could make one
ron |
#19 |
yes I can and will do so in a day or two, but always like to stay oem if I can. Thanks again.
