Old 07-07-2015, 12:37 AM   #1
SnS C10
SnS C10's Avatar
so I cut my rear coil springs and....
What an amazing difference!!! I cut exactly two coils off the top of the spring and it dropped the truck exactly 4 inches. I also removed the bump stops. When I drove the truck it was super smooth, better than stock. I positioned the cut section of coil under the frame. It looks and feels safe while driving. The front of the truck has 1.5 coils cut also. Got tons of looks and thumbs up!! Tires sizes are 225/60/15 and 31x10.5x15
SnS C10 is offline   Reply With Quote
Old 07-07-2015, 06:34 AM   #2
PGSigns
PGSigns's Avatar
Re: so I cut my rear coil springs and....
What you will find over time is the rear coil will wear into the frame from being able to move around with out the locator on it any more. If you like the look try and find a set of springs.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 07-07-2015, 09:51 AM   #3
TJ's Chevy
TJ's Chevy's Avatar
PG Signs is right...though for now its a awesome idea and GOOD work doing it! In the long run it will be better to find a set of lowering coils. Early Classic has Lot's of stuff for your convenience.
Old 07-07-2015, 11:08 AM   #4
SnS C10
SnS C10's Avatar
Yea I planned on buying a set. Since these were coming out anyway I figured let's try the cut and see how it goes as the truck only gets driven less than 5 miles per week
Old 07-07-2015, 12:47 PM   #5
chevy2junk
chevy2junk's Avatar
Find a peice of metal pipe that fits the outer diameter of the coil.Cap it and make a spring retainer cup that bolts in.Simple fab skills minimal money.Also will work going inside same principle as the stock retainer cups.
chevy2junk is offline   Reply With Quote
