1966 c60 wheel cylinder problems
Having a hard time sourcing new wheel cylinders and the ones I have found are high(100+). Has anyone ever had success rebuilding wheel cylinders? Rebuild kit is 8$
Posted via Mobile Device |
Re: 1966 c60 wheel cylinder problems
i've rebuilt wheel cylinders before. It's pretty easy.
make sure you find a centrifugal hone, some brake fluid, and the kit. If you can, hot tank, or wire wheel the crap off the cylinder and if possible let sit in some vinegar overnight. put some WD-40 or paint them when they come out of the vinegar as they may flash rust. Hone the bore, clean the bleeder passage and reassemble.
2013 Malibu LTZ 1996 C1500 4.3/5spd 2wd |
#3 | |
![]() Never had one come back that I recall. I never even pulled them off; just cleaned everything up and honed them in place with a spring loaded hone chucked into an electric drill. Just make sure the cups are installed with the hollow side towards the brake fluid (inside). You probably want to put in new rear axle seals while you have the hub apart to get at the brakes.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
![]() Join Date: Jul 2007
I have done a bunch. As stated in earlier posts a small hone and brake fluid is needed. run it in a few times and it should have about a 45degree pattern. Look for rust pitting. If it has pitting it may need replacing. Napa had wheel cylinders for $15-18.
#5 | |
#6 | |
http://www.autozone.com/test-scan-an...-cylinder-hone I always just used the ones that the shop already had ![]() ![]()
they are about $20 in the Denver area at most auto parts stores. LMC has them for about the same or all four for $69.95. plus shipping of course.
