Old 07-30-2015, 01:31 PM   #1
lyrikz
PITbut
lyrikz's Avatar
Question about custom rims and narrowed rear ends.
Where are you guys ordering your custom rims from?
Also, any good recommendations on where i can send my rear end to have it narrowed?
Thanks.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 07-30-2015, 02:54 PM   #2
BossHogg69
motor exploder
BossHogg69's Avatar
Re: Question about custom rims and narrowed rear ends.
I talked to both Schott Performance and Boze Alloys and ended up getting a set from Schott, both offer very nice wheels. My '69 C10 rear is narrowed 2", I had it done locally at a racing/fab shop (Shahan Racing in Cabot, AR). Just about any machine/fab shop should be able to do it. If you have any dedicated 4x4 or heavy duty 'spring/brake' shops they may be able to do it as well.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 07-30-2015, 08:55 PM   #3
Livrat
Member #1049
Livrat's Avatar
Del, for rear end narrowing check out Bill Scribner in Kent, Wa
http://www.scribnerwelding.com/home.html
Livrat is offline   Reply With Quote
Old 07-30-2015, 11:33 PM   #4
Robznob11
Robznob11's Avatar
You wanting big rims? How wide you wanting you can fit 12 wide with 7 1/2 bs on the wider rear 70+ I have 12 wide with 6.5 bs on the 68 narrow rear. If your wanting big rims for cheap discount tire offers some 20x 12s with deep bs made by rino in the 5 on 5 bolt pattern with smaller or narrower rims to match for front. I thought about getting some but my rear axleshave been made with 5 on 4 3/4 bs.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 07-30-2015, 11:41 PM   #5
Robznob11
Robznob11's Avatar
Cool Re: Question about custom rims and narrowed rear ends.
I sure wish I could afford this deep dish look tho !https://youtu.be/mb656X4U9jc
LED TAILS
Old 07-31-2015, 08:56 AM   #6
BossHogg69
motor exploder
BossHogg69's Avatar
You have any pics of your setup? Stock wheel houses or did you widen them some? Does anything rub?
Adam
Old 07-31-2015, 09:36 AM   #7
Robznob11
Robznob11's Avatar
I have not built the tubs yet but you need them to clear. You can run a mt 18.5 on these trucks with tubs only ( coil spring)
LED TAILS
Old 07-31-2015, 12:00 PM   #8
BossHogg69
motor exploder
BossHogg69's Avatar
That's what had me wondering - you didn't mention cutting the tubs, which I know is mandatory to tuck a 12" wide wheel with a 345 section tire, because that's what I'm running too. Just wanted to make sure we were on the same page.
Adam
Old 07-31-2015, 12:02 PM   #9
lyrikz
PITbut
lyrikz's Avatar
Thank you sir.
Yes, i want a big, wide rim with a HUGE lip. I want 7+ inches of rim lip. 12 inch rim. 15" rear tire. This build is the first one im doing where i want everything done that i have never done in past builds. I always just went the easy way. Not this time.
and sold.
