Old 07-30-2015, 04:34 PM   #1
stacerbob
BODY SHOP SUPPLIES INC.
stacerbob's Avatar
K-10 exhaust ?
Need to redo the exhaust on my K10 & looking for suggestions. It has 2" ram horns on it, I either want to go to the speedway motors 2.5" manifolds and a Y-pipe to 3" single or headers with duals and run them outside the frame.
stacerbob is offline   Reply With Quote
Old 07-30-2015, 08:08 PM   #2
Re: K-10 exhaust ?
2.5" into a single 3" sounds self-defeating. You'll get much better results with 2.5" pipes. Running 3" is not so easy to do compared to 2.5 and I believe in letting both banks empty themselves. I just go to the exhaust shop and tell them what I want
Old 07-31-2015, 01:49 PM   #3
mrein3
mrein3's Avatar
Re: K-10 exhaust ?
Except for a recent report here that the Heartthrob dual exhaust kit offered by LMC wasn't properly manufactured, I've heard nothing but good things about their dual kits. I put one on over 12 years ago.
http://www.heartthrobexhaust.com/
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 07-31-2015, 03:45 PM   #4
Mike C
Mike C's Avatar
Re: K-10 exhaust ?
I would NOT put the pipes outside the frame. I would do 2 1/2" the whole way with the 'vette manifolds. And that IS what I did on the Jimmy. I think the balance/y pipe is a good idea. Run the exhaust over the axles and out the side at a 45 degree angle.
4x4 should never run pipes straight out the back. If you have to rock it or drive it backwards in mud/water it packs in the exhuast. 90 degree bend too restrictive IMO, so the the 45 is the anser.
Old 07-31-2015, 11:34 PM   #5
Re: K-10 exhaust ?
90 degrees works just fine. I like the look better and you will not see a difference in performance. It's more a matter of personal preference. I agree about straight out the back on 4wds...that actually get down and dirty
Old 08-01-2015, 08:17 AM   #6
Daman
Re: K-10 exhaust ?
I used the Hearthrob kit and it worked great with the 2 1/2 ramshorn
Daman is offline   Reply With Quote
Old 08-01-2015, 09:19 AM   #7
FlameOut
Re: K-10 exhaust ?
I also used Heartthrob dual kit on my 72 K10 with stock ramhorns. Perfect fit. Bought from autoanything.com for under $200
2004 Chevy Silverado Z71 Ext Cab 1500
1972 Chevy K-10 SOLD
1967 Chevelle SS
FlameOut is offline   Reply With Quote
