Old 08-01-2015, 05:50 PM   #1
missionstreettattoo
missionstreettattoo's Avatar
1968 C10 with inline 6 question
If i were to put a souped up 454 in the truck, is the front end able to hold up?
missionstreettattoo is offline   Reply With Quote
Old 08-01-2015, 06:19 PM   #2
wd 69
wd 69's Avatar
Re: 1968 C10 with inline 6 question
I'm pretty sure that from the factory the trucks with the V-8s had heavier springs. . .
Sure somebody else will be able to give specific info.
You know, that 6 cylinder is an awful good engine. . . Does yours run currently?
wd 69 is offline   Reply With Quote
Old 08-01-2015, 06:48 PM   #3
missionstreettattoo
yes it does, the damn three on the tree and transmission constantly giving me issues.
Old 08-01-2015, 06:54 PM   #4
wd 69
wd 69's Avatar
I've been lucky so far with my 3 speed on the column, but I have always heard about the problems that seem to be frequent enough.
Really do like my 250, not a "hot rod," though. Just a tame, half ton farm truck.
Old 08-01-2015, 07:21 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Just put big block springs up front... It'll "hold up" just fine...
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 08-01-2015, 07:49 PM   #6
hugger6933
The big difference between the trucks with 250, 350 or 396 was the spring I think. They will be broken down probably into six[6] areas. Six cyl then six with air. Small block then small block with air then big block and big block with air, but there may be HD spring thrown into each one of those categories.
hugger6933 is offline   Reply With Quote
Old 08-01-2015, 07:59 PM   #7
CST10
CST10's Avatar
Change the springs to HD type and you'll be fine.
I'd keep the lil 6 in storage invade you ever want to go back.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 08-02-2015, 02:59 AM   #8
ViviensTractor5110
I just put a 400 small block in an original six truck with no issues. Spid states "HD" springs but I'm willing to bet they are all equal after 40 years. The springs that is.
ViviensTractor5110 is offline   Reply With Quote
