Old 08-02-2015, 11:47 AM   #1
54blackhornet
54blackhornet's Avatar
Changed Plugs Now No Start ?
I swapped in a set of plugs on my 71 C-20, 307 now it won't start ? It was running crappy and the plugs where pretty fouled. It has gas at carb but it just won't fire, it tries too start but won't ? Crazy because it's bone stock and has been reliable for years. Any suggestions ?
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 08-02-2015, 12:15 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Changed Plugs Now No Start ?
Plug wires connected to wrong plug(s)? Trace wires from the distributor. Check and double check. How old are the wires?
FirstOwner69 is offline   Reply With Quote
Old 08-02-2015, 12:46 PM   #3
9teen69
9teen69's Avatar
Originally Posted by firstowner69 View Post
plug wires connected to wrong plug(s)? Trace wires from the distributor. Check and double check. How old are the wires?
x2
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 08-02-2015, 01:20 PM   #4
hugger6933
Make sure the coil wire didn't get bumped. Jim
hugger6933 is offline   Reply With Quote
Old 08-02-2015, 06:17 PM   #5
Redline novdog
Redline novdog's Avatar
Electrical things can go at any time.Got spark? if not coil? Points Condenser in distributor, knocked a wire off the coil/plug wires on wrong? Sorry for the long list but in my years I've been/done all of them.Just changing plugs didn't do that.something went away out of your control.
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 08-03-2015, 09:40 AM   #6
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Pull the coil wire from the distributer and lay it on top of the cap above the hole. Have someone turn the engine over. You should see and hear the ark going into the distributer cap. That will tell you if you have fire. If you have fire there, then check for ark at the plugs. If you have it there, then check the fuel supply. Remember, you have to have fire and gas to make the engine run.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
