Transmission AN fittings
For all you guys that want to run AN fitting for your trans and hook up to your cooler in your radiator. After a lot of searching I found the correct fitting from Russell.
Re: Transmission AN fittings
Nice work
James B. 1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful) 1971 Chevy Fleetside Shortbed 4X4 (White & Rough) |
#3 | |
Can't seem to find the part number from summit at the moment. |
I've found the correct ones for the transmission, but not the radiator.
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
I'm curious why someone would go to a different fitting, given that the inverted flare fitting has worked so well for so many years?
Ok, thanks for the part #
![]() Join Date: Jul 2015
So you can use an fittings, maybe he wants to run braided hose and not hard steel lines.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
| Bookmarks |
