Old 08-04-2015, 03:53 PM   #1
canadian_diesel1964
1963 manual idler arm bracket differences
Hey all...hope your enjoying your summer..I got me an old school k14 moog idler arm for my manual steer 63. The old idler had a straight bracket and the new one has this curved bracket...did I put it on backwards? There was a spacer provided on the back side of the old idler ...not sure on this one...thx!
canadian_diesel1964 is offline   Reply With Quote
Old 08-04-2015, 03:54 PM   #2
canadian_diesel1964
Re: 1963 manual idler arm bracket differences
New one here ...
Old 08-04-2015, 04:53 PM   #3
1963c-10
1963c-10's Avatar
My moog replacement is straight. I'll have to look at which part # I used.
1964 Short bed trailer
Old 08-04-2015, 10:03 PM   #4
frankslagoon
63 SB I remember scratchen my head too. this how it ended up. works good.
frankslagoon is offline   Reply With Quote
Old 08-04-2015, 11:47 PM   #5
Lugnutz65
Lugnutz65's Avatar
The picture below is not the best, but I know it is correct. The idler arm with a bend in it should have the spacer between the frame and the lower hole. So your photo shows that you have it twisted 180 degrees.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 08-05-2015, 05:01 AM   #6
frankslagoon
Originally Posted by lugnutz65 View Post
the picture below is not the best, but i know it is correct. The idler arm with a bend in it should have the spacer between the frame and the lower hole. So your photo shows that you have it twisted 180 degrees.
x2
Old 08-05-2015, 02:56 PM   #7
canadian_diesel1964
Thanx guys ...it came to me last night....got re done as your can see.....
