Old 08-20-2015, 01:32 PM   #1
68Stepper
CLR Treatment for surface rust question
Quick question on the CLR process.
Do I need to neutralize the CLR afterwards with a base such as baking soda? There are several posts about the CLR thing but this was never answered.
After I've given my truck the CLR bath with green scotch brite pads, do I keep the whole truck wet just as if I was washing a normal car? Or are you supposed to immeditately dry each treated panel after the CLR is scrubbed and rinsed with water? I saw on a thread that rust would immediately form if you didn't dry it completely immediately after the treatment.
Please clarify,
68Stepper is offline   Reply With Quote
Old 08-20-2015, 06:17 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: CLR Treatment for surface rust question
Please clarify,
The baking soda would neutralize any acid present. I would do one area at a time and rinse it good with cold water. It wouldn't hurt to dry it as you go but you will probably get it wet again when you do adjacent areas....
LockDoc
Leon
Old 08-20-2015, 06:33 PM   #3
kingsolver72
10/30/19
kingsolver72's Avatar
I don't think I'd put baking soda on it. Just wash and let it dry.
I definitely wouldn't apply baking soda if it were to be painted.
Fight the good fight, finish the race, keep the faith
kingsolver72 is offline   Reply With Quote
Old 08-20-2015, 09:06 PM   #4
Hosing it off dilutes the acid just fine. It's a weak solution to begin with. I've never done anything but scrub and rinse. If you are still concerned, just go ahead and give it a normal wash
Old 08-20-2015, 09:20 PM   #5
Tim Christian
Tim Christian's Avatar
Wear gloves
Tim Christian is offline   Reply With Quote
Old 08-20-2015, 10:17 PM   #6
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I did a piece on the box side on atruck I had . I just used the CLR and dint even rinse it. I did it in Sept/Oct and the truck sat outside all Winter and no rust came back by spring. If I was doing lots on a truck I'd be rinsing after.
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 08-21-2015, 10:19 AM   #7
68Stepper
Sounds good, I appreciate the help. Thanks for the info!!
