08-30-2015, 11:53 AM | #1 |
Upper clutch rod
The pic is the end of my upper clutch rod that connects to the bell crank. Is that groove supposed to be there, or am j lucky it has not broken get? It is on my 67 C10 with 3 speed.
08-30-2015, 11:57 AM | #2 |
The Older Generation
Re: Upper clutch rod
It is supposed to be round with no groove in it. I would check the parts board on here to see if someone has one for sale. You can't post a "want to buy" because you aren't a "Premium" member but if you see one for sale you can buy it. You could also check your local salvage yards if you have any. LockDoc
08-30-2015, 12:51 PM | #3 |
Thats worn out. Mine looked the same at both ends. I welded it up and ground it back to round and it works fine. Better feel to the clutch too.
I bought parts to make up a new rod with him joints, but haven't gotten around to doing it yet.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
08-30-2015, 04:49 PM | #4 |
I went with Heim Joints on my '68 C/10 w/292 L6. My machinist made it for me, not the LMC junk. The V8 upper clutch rods [the bent ones] may still be available from some vendors. Most junkyard examples would be severely grooved, as the OEM part was some kind of pot metal and wore thru quick.
08-31-2015, 04:23 PM | #5 |
I'm glad you mentioned the other end, I pulled it and it is as bad as this end. My son welded it up and I did the grinding. It is amazing how much slop that removed from the linkage. Thanks!
