Old 08-26-2015, 04:39 PM   #1
lowlyfec10
4L80E pan hangs below frame
so im running all cpp stands/mounts/sliders/trans member and i peeked under the truck to see the trans pan hanging about an inch below the frame.
options cuz she wont lay frame with that.....
lowlyfec10 is offline   Reply With Quote
Old 08-29-2015, 09:52 AM   #2
toddoky
Re: 4L80E pan hangs below frame
You don't say what year your truck is, so It may or may not be helpful for you to know that the new Hooker 73-87 GM truck swap system leaves no components hanging below the frame rails.
toddoky is offline   Reply With Quote
Old 08-29-2015, 10:02 AM   #3
lowlyfec10
Sorry.... 69
Old 08-29-2015, 10:56 AM   #4
toddoky
Sorry.... 69
Gotcha. I wish I had a fix for you, but we haven't gotten around to developing swap parts for that application yet.
Old 08-30-2015, 02:00 PM   #5
tinydb84
tinydb84's Avatar
What is your trans angle at? You might be able to lift the trans a bit to get more clearance.
David
Instagram: myfabguy
Old 08-31-2015, 01:22 PM   #6
Hart_Rod
Hart_Rod's Avatar
Hart_Rod is offline   Reply With Quote
Old 08-31-2015, 01:54 PM   #7
lowlyfec10
you need pix of the pan hanging lower than the frame? lol i'll snap some tonight and get a rough measurement.
havent checked angles yet, but i need to soon so i can get my driveshaft shortened once my new spicer slip yoke comes in.
im running all cpp stuff with the ES poly mounts....i guess i could call them and see if they might know roughly how the drivetrain sits.
i do know....that if i have to raise the trans some....it'll be time for a high hump cuz i had to flatten the lip out to make the trans clear with how far back it is now.
btw, hart_rod.....havent scanned enough to find a legit answer but suggestions on where to run the dbw pedal harness thru the firewall once your bracket is bolted in...which looks noice btw....
Old 08-31-2015, 03:36 PM   #8
jackyl9999
jackyl9999's Avatar
I used a aftermarket tubular cross member and had to use about a 2.5" spacer to get my drive line angle correct.
So don't get too upset until you get your angle set. I remember looking at my pan thinking "there is no way this is going to work like this"
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e)
1990 K1500 Daily
jackyl9999 is offline   Reply With Quote
Old 08-31-2015, 04:36 PM   #9
lowlyfec10
oh im not upset. just something i noticed that would need to be addressed after i got the LS running....since dropmember and bags are the next step lol
