Old 09-25-2015, 08:30 AM   #1
v30crewcab
v30crewcab's Avatar
69 blazer disk brake swap?
buddy has a 69 k5 blazer 4x4, and wants to do a disk brake swap. anyone know of any complete kits for it? he'd like to do front and rear both. was thinking of swapping the front axle to a newer one but read somewhere they were wider.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 09-25-2015, 09:15 AM   #2
andrewmp6
Re: 69 blazer disk brake swap?
As far as i know the front axle from a 73-87 will bolt in it,Not sure on if its wider or not.
Old 09-26-2015, 01:13 AM   #3
argonaut
argonaut's Avatar
I'm pretty sure that pickup d44 front axles are wider than blazers in the 60-72 years. But even if that is the case, no one will know but you.
Although another option would be to get the disk brake axle and then swap everything from the knuckles out onto your axle housing. You'll also need to use your inner axle shafts connected to the disk stub shafts. Great opportunity to install new ball joints and new u-joints.
For the rear 12 bolt, there are many kits to adapt small calipers. Don't buy the kit that CPP sells, it doesn't fit well in my experience.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 09-26-2015, 05:10 PM   #4
v30crewcab
v30crewcab's Avatar
if the truck axle is wider, the inner axles would be longer too. hows that gonna work? so cpp stuff dont work? hmm. was looking to get a kit so its quick and painless to do.
71 longbed 5.3 4l80
Old 09-26-2015, 10:53 PM   #5
argonaut
argonaut's Avatar
What you said is correct. That's why I suggested what I did.
Use your blazer axle housing and inner axle shafts. Use the outer shafts, knuckles, spindles, hubs and rotors from a disk brake axle.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 09-26-2015, 10:56 PM   #6
argonaut
argonaut's Avatar
It's not that the CPP stuff won't work. I bought it and made it work on my 2wd 12bolt. But it wasn't a good design, and I had to spend more money to make the parts work correctly, and the CPP folds wouldn't help.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 09-27-2015, 04:59 PM   #7
v30crewcab
v30crewcab's Avatar
can't swap later disc brake outer stubs, the ujoint sizes are different. so you gotta swap inners also, which means custom. guess we're gonna have to swap the whole axle out.
71 longbed 5.3 4l80
Old 09-28-2015, 02:01 AM   #8
andrewmp6
If he just wants a normal truck a 10 bolt front is fine,If he wants a off roader id think hard about a dana 60 gm or early dodge will do.
Old 09-28-2015, 07:58 AM   #9
v30crewcab
v30crewcab's Avatar
its just a driver.
71 longbed 5.3 4l80
