Old 02-20-2004, 01:13 AM   #26
bobbys1967
Have the coil checked as well.
1970 K10
bobbys1967 is offline   Reply With Quote
Old 02-20-2004, 01:20 AM   #27
bad 71 chevy
bad 71 chevy's Avatar
i know when i instaled my tac it did the same think i do not have an hei but i had the wires switched on the coil
71 Chevy C/10 lwb 350
5 speed nv3500
3.73 rear end
2.5" Front Drop and 4" in the back
Edelbrock perfomer rpm manifold
Edelbrock 600 cfm carb
Headmen headers
bad 71 chevy is offline   Reply With Quote
Old 02-20-2004, 02:38 AM   #28
jhow66
jhow66's Avatar
Have you unhooked the tach and tried it?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 02-20-2004, 03:15 AM   #29
Blue_71
Bloo
Blue_71's Avatar
Replaced the module (thing that sits on top of the dist. under the dust cap), and still no luck
unless im missing what your saying, that is the coil
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 02-20-2004, 04:14 AM   #30
ckenwright
ckenwright's Avatar
First, check that you have 12 volts at the coil during startup. Not just in the on position. Then make sure that all the wiring to the coil is hooked to the correct connections ( the coil will not work with the wires in the reverse positions.) If these items are good then disconnect the ground wire from the coil and check for 0 or close to 0 ohms from the end of the wire you disconnected to the engine block. If all these are good then remove all the ignition components and take them to an autoparts store or mechanic to have them tested. Hope this helps a little.
ckenwright is offline   Reply With Quote
Old 02-21-2004, 12:57 AM   #31
72superBB
72superBB's Avatar
I replaced the module under the rotor and still no luck. I will replace the cap and rotor, just to make sure that is not it. After that, I am not sure which way I will go.
Ron
Life is full of choices and a Chevy is the best choice.
1990 Chevy SWB
72superBB is offline   Reply With Quote
Old 02-21-2004, 01:40 AM   #32
walker
walker's Avatar
If it were me in your shoes after all you've done so far I would first run a jumper wire from the batt terminal to the battery and try to start her. Then, if it doesn't start, I would pull out a spark plug, plug the wire back on it, ground it( I use a jumper cableon the neg batt terminal on one end and grab the spark plug body on the other end, makes it easier to do by yourself) try to start it and check for sparks. If no sparks, you have eliminated the wiring to the dist. Then I would pull the cap and check the dist wiring, make sure the ground strap was in there, check the module. While you are in there you might spin the engine and make sure the rotor turns, etc.
Also, since you say you installed a tach, you might uninstall it and try the engine then.
Good luck.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 02-21-2004, 01:54 AM   #33
ckenwright
ckenwright's Avatar
Also take off the cap and turn the engine over to see if the rotor is turning. You might have sheared the pin in the shaft.
Old 02-22-2004, 07:17 PM   #34
72superBB
72superBB's Avatar
Ok, lets see.
Rotor turns, not sheared. Noticed that when I got it TDC
Replaced the coil (under the cap)
Replaced the module. (Banana shaped thing)
Pull dizzy and took it apart & replaced the thing around the shaft.
Still will not start.
Still no spark to the plugs.
Lost now!
Ron
1990 Chevy SWB
Old 02-22-2004, 08:03 PM   #35
jef5150
Inline 69
jef5150's Avatar
so this truck was running, you parked it, installed a tach, now it wont start? youve replaced alot of stuff and still wont start!!, id go "double" check that every thing is hooked up correctly. heres a diagrahm and a link http://67-72chevytrucks.com/vboard/s...threadid=13698 jeff
jef5150 is offline   Reply With Quote
Old 02-22-2004, 08:34 PM   #36
72superBB
72superBB's Avatar
Hey Jeff,
I have done that several times. I cannot get passed the fact of power to the dizzy, but not after. What would cause no spark? I have not replaced the cap & rotor yet, because they are still fairly new. Have hardly any marks on them.
Before I parked it, I was having trouble starting then to, but it started. If it was running, then it would be real hard to restart.
WHen that happened, I replaced the fuel filter.
So, I have no spark after the dizzy. I will replace the cap & rotor to see if that does it, but if it does not, then what else would there be?
Ron
1990 Chevy SWB
Old 02-22-2004, 08:38 PM   #37
Bowtie67
Bowtie67's Avatar
Post
When all else seams to fail start at the beginning to resolve problem.
1. Check the Ditributer Rotor, GM rotors were notorious for burning a hole through the rotor, you will have to pull off and look underneath of it, if you see a black burnt spot, this will do it..I have seen new rotors burn through in what seems likee no time at all.
2. Make sure you have voltage to Distributer and disconnect Tach to eliminate possible issue,
3. You replaced coil (new Coil?) under the HEI cap, which there should also be a ground under the coil,
4. Check cap to make sure the center elctrode is there, you should have gotten new one with coil and replaced as well.
5. check when you are cranking engine the 12 volt lead to distributer has voltage while cranking.
6. The plugin from distributer to cap is also plugged in.
7. DOuble check grounds, run jumper cable from frame to engine and Negative battery terminal to frame.
7. If still no spark. You have a serous problem.
Bowtie67 is offline   Reply With Quote
Old 02-22-2004, 09:52 PM   #38
Huck
Huck's Avatar
I have the same problem on a SWB in my yard. It ran but poorly so I tried to move it and it just wouldn't start anymore. I cranked and cranked, checked gas -OK, changed module----no spark to plugs but 12V to the dist.'
I think it is the little condenser in the distributor. I had a similar problem 2 years ago and it drove me nuts. It's cheep, easy to change and often overlooked. worth a shot---.
good luck
Huck is offline   Reply With Quote
Old 02-22-2004, 11:24 PM   #39
72superBB
72superBB's Avatar
What does the condenser look like? Is it the round tube looking thing?
Ron
1990 Chevy SWB
Old 02-23-2004, 01:29 AM   #40
jhow66
jhow66's Avatar
Right--it has nothing to do with running on a HEI-it is there for noise filter for radio. Of course if it is grounded out inside it will kill your spark. Just disconnect it and see if it will start. (condenser has a purpose on a points ingnition)
Old 02-23-2004, 01:47 AM   #41
SCOTI
SCOTI's Avatar
Since it sounds as if the HEI was previously installed, how did it run before? It sounds like a ground issue or voltage to the HEI itself is a problem.
When you say you have voltage @ the distributor but not after, exactly how much voltage do you have (for sure)? Run a hot wire (10guage) from an ign-unfused source on the fuse-block directly to the batt terminal on the distributor & see what happens. If the rotor is turning (no broken timing chain) you should have spark. No spark, look @ the coil & it's ground strap.
Keep us posted. We all love a good mystery......we just hate it when it happens to one of us & in this way!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-23-2004, 02:24 PM   #42
67chevy2wd
67chevy2wd's Avatar
i personally at this point replace the distubutator and see what happens
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 02-23-2004, 03:57 PM   #43
trinic
trinic's Avatar
You said it's been sitting for a while. Make sure your tires are at the correct air pressure, and that your radiator is topped off....j/k
assuming you have power to the distributor, and assuming you confirmed that it's the spark that's absent and not fuel or a broken timing chain, there are three things it could be. Listed in the order of failure in my experience (1)the pickup coil, (2) the modual, (3) ignition coil
trinic is offline   Reply With Quote
Old 02-23-2004, 03:58 PM   #44
trinic
trinic's Avatar
pickup
pickup coil image
Old 02-23-2004, 04:06 PM   #45
67chevy2wd
67chevy2wd's Avatar
you said that you ckecked for spark against the inner fender and i am not 100% sure on this but maybe it won't ark through the paint or will it. That is just my $0.02. I am probably wrong but what the heck it never hurts to speak your opinion does it?
Old 02-23-2004, 04:28 PM   #46
jorgensensc
jorgensensc's Avatar
Did you do any ignition switch work? I had a similar problem after I rehooked up my ignition switch. The dizzy would get power in the on position, but when put in the sart position would not get power. I had 2 wires backwards on the ignition switch. One wire interrupts power when cranking(start position)so to give all the power to the starter (ie radio, A.C., etc), When put in run position it gets power again. The other wire gets power all the time when ignition turned to start or run. These 2 wires were backwards, so I switched and then it worked fine. Maybe your ignition switch went bad? Hope this helps a little. Good luck!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 02-23-2004, 09:56 PM   #47
Huck
Huck's Avatar
Found my problem on my SWB this afternoon. Forgot to put the two screws back in the Module that mount it to the Dist top plate. After I did that, the bugger kicked off fine. Now how I forgot them little screws---well let's just say "Brain Fart!" Da!!!
Old 02-23-2004, 10:19 PM   #48
superfly68
superfly68's Avatar
glad to hear you found it. been waiting for that post. I hate it when it's my fault!
no longer have a ride, but still a fan!
superfly68 is offline   Reply With Quote
Old 03-09-2004, 03:11 PM   #49
Yellow Cheyenne
Check the pickup coil (white donut shape with two wires coming out of it-you must remove the dist shaft from the dist housing to replace the coil) as suggested above. Had one that after a few years one of the wires broke due to fatigue and constant movement from the vacuum advance. And yes, the 12v supply to the dist should be there during cranking and while running. Means the latest thing you have done is add the tach, unhook the tach wire from the dist and see if any symptoms change. I would also leave it unhooked until the vehicle is running again. Once it runs, then hook the tach wire back up.
Randy
'72 Cheyenne. AC, PS, PB, Rear slider window, tilt. Light yellow (grapefruit yellow according to new sales literature from '72)
'56 Chevy short step V-8 (My dad bought it new!!)
'70 Olds 442 convertible
'70 Olds Rallye 350
Yellow Cheyenne is offline   Reply With Quote
Old 03-09-2004, 03:14 PM   #50
Yellow Cheyenne
Started to write my suggestions, got interuppted, finished writing and posted. There has been about 6 posts since I started the post. Glad to hear you got it running.
Randy
'70 Olds Rallye 350
